Three Blades 0 Posted January 28, 2013 Share Posted January 28, 2013 I have just finished repairing the main harness on my 1999 Td5 after a broken power wire shorted into an information cable and turned it into an electric radiator.Many thanks to Western and other contributors for supplying tips and wiring diagrams to the forum that significantly helped me on my way.I had a final problem when the starter would not engage. I traced it down to a faulty connection between the 10AS and the relay but needed the pin out for the 10AS to help with this.I found the diagram and details in this link from an Aussie forum helpful and thought that the mods may liketo put it in the tech archive (assuming it is not already there): http://www.aulro.com/afvb/90-110-130-defender-county/163070-td5-defender-alarm-query.html 10AS Grey plug connectionsAnd here is the Green Plug connections Link to post Share on other sites
western 850 Posted January 28, 2013 Share Posted January 28, 2013 now stored in the tech archive. Link to post Share on other sites
western 850 Posted February 1, 2013 Share Posted February 1, 2013 additional info used by Three Blades to sort his problem http://www.blackbox-...help/SM031.htmlThere are descriptions on what each of the settings do in the 10AS as well.I've gotten quite a fair bit of info from this description when i was working on my 10AS project from farmer spec to full spec alarm. Link to post Share on other sites
