Homemade tools/machines
o_teunico
 Share
  • 2 weeks later...
I'm toying with the idea of building a small vertical borer...... I think a Boxford lathe like mine stood on end, with a new thrust bearing to take the load...... keep thingking....
Other than floor space theres nothing to be gained by having a small vertical borer other than the novalty factor...
we've 800mm Carnaghi, 48" W&B, 1900mm Schiess, 2440mm Berthiez :) :) :) :) :) :)
Ha! I forgot the Schiess, twin table jobbie, probably about the same size as yours :D
We make epicyclic gears, big ones, upto about 40T, fixed input/output ratio's, so turn lots of rings to cut teeth on.
 Share
