parrysean Posted February 1, 2013 Share Posted February 1, 2013 hi there can someone please help me in the right direction .I have had the head done on my v8 .After this it was pressurising the water so it went back to the garage only to find that the wrong gasket has been fitted .This has been rectified by fitting new and right gasket .Its not pressurising the water now but its ok when its cold but as soon as its warm the revs are up and down like a yoyo and in the end will just cut out .Its lpg converted as well and will tick over on lpg and rev but when you try and drive it justs cuts out again as its got no power .The garage has checked for air leaks and says there are none .If anyone can give me some guidence as to where to start i would be greatful thanks sean Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted February 1, 2013 Share Posted February 1, 2013 Moved to the Discovery forum Quote Link to comment Share on other sites More sharing options...
mikeyb13 Posted February 1, 2013 Share Posted February 1, 2013 Have they checked temp sensor, stepper motor and maf? Quote Link to comment Share on other sites More sharing options...
teabag Posted February 2, 2013 Share Posted February 2, 2013 I'd go for the Efi temp sensor first, could be faulty or even a simple iffy plug connection. And Welcome to the Forum Quote Link to comment Share on other sites More sharing options...
