alfy Posted February 6, 2013 Share Posted February 6, 2013 Hi guys - new here, LR4x4.com - first post few weeks ago rear wiper stopped working - no real issue - but this week the indicators stopped and also temp gauge, fuel gauge,and speedo - checked the fuse box ( f8 blown ) 3rd from right !!! (10 amp ) changed it - all ok for 2 days --- then it blew again ! now it keeps blowing all the time - I dis -connected most things -- wiper sw, all gauge's , relays, stalks -- but still blows Any ideas chaps Thanks alfy Quote Link to comment Share on other sites More sharing options...
Snagger Posted February 7, 2013 Share Posted February 7, 2013 There's a short somewhere. Disconnect every wire from the fuse output and then reconnect them one at a time to find the faulty circuit. Once you have done that, you need to systematically work through that circuit - I'd start by disconnecting the other end of that feed wire and connecting it to the fuse; if it blows, you know the fault is in that wire, if it doesn't, add the next component in the circuit (but disconnected at its other end), so you gradually work through that circuit proving each component as you go until the fuse blows - as soon as the fuse blows, you have found your bad component. Quote Link to comment Share on other sites More sharing options...
alfy Posted February 7, 2013 Author Share Posted February 7, 2013 Thanks - i have dis all the wires from the rear door / stalks, all dash dials - still the fuse blows, not sure what fuse 8 covers - apart from the rear wiper - the LR manual mentions haz lights -- but these work ok fuse 8 details of what it feeds is limited in the manual !!! Thx Quote Link to comment Share on other sites More sharing options...
NickMc Posted February 8, 2013 Share Posted February 8, 2013 Check the white earth header block bolted to the bulkhead, beside the expansion tank. Most of the dash is earthed there. Quote Link to comment Share on other sites More sharing options...
carlosbeldia Posted February 8, 2013 Share Posted February 8, 2013 Not, it's an unknown earth behind the dashboard, but it's facing the interior of the car. I mean, you have to take all the plastic things to reach all the cables and this earth point. I had this exact problem during 2 years, had to disarm all the car in order to fix it, because the car started juddering after a while blowing fuses... Quote Link to comment Share on other sites More sharing options...
alfy Posted February 8, 2013 Author Share Posted February 8, 2013 Thanks guys - I will chase all these avenues - I may also look at the fuse box as well alfy Quote Link to comment Share on other sites More sharing options...
alfy Posted February 9, 2013 Author Share Posted February 9, 2013 Hi I checked the fuse box F8 -- all intact, all earths seem ok, Does not seem to be an earth issue - as it blows the fuse straight away ( a direct short ) Theres a white wire input into F8 from ing 12v+, on the other side of F8 theres a thiner white wire go away to ?????????? I have checked and its got a direct short to earth !!! ( fault ) Q - where does this thiner white wire go to >>>>> is it to a relay if so where is it located ?? Thanks alfy Quote Link to comment Share on other sites More sharing options...
western Posted February 9, 2013 Share Posted February 9, 2013 in my 1999 td5 wiring diagram fuse 8 has a white/brown tracer wire from fuseible link 5 in the engine compartment fusebox & a plain purple wire to the diagnostic socket, no other wires. Quote Link to comment Share on other sites More sharing options...
alfy Posted February 9, 2013 Author Share Posted February 9, 2013 my small brain hurts now - maybe I got it wrong fuse box that sits at the dash / gearbox theres 20 fuses / 2 rows of 10 its on the top row ---8th from left / or 3rd from right thick white wire in and thin white out ( 10 amp ) thx alfy Quote Link to comment Share on other sites More sharing options...
western Posted February 9, 2013 Share Posted February 9, 2013 that's fuse 3 not 8, the attached pages will tell you which circuits fuse 3 takes care of. Quote Link to comment Share on other sites More sharing options...
alfy Posted February 10, 2013 Author Share Posted February 10, 2013 NICE one thanks - will start again alfy Quote Link to comment Share on other sites More sharing options...
alfy Posted March 8, 2013 Author Share Posted March 8, 2013 Hi chaps - tried everything still ongoing issue - had an auto electrician check it - he said he repaired the loom - and now the fuse does not blow - but now after a week -- >> when i brake the rear indicators also light up / when i indicate the brake lights also flash - also the warning lights on the dash also flash even the water in fuel light very strange --- maybe an earth issue at the rear !!!!!!! any ideas thanks alfy Quote Link to comment Share on other sites More sharing options...
Hazza Posted March 9, 2013 Share Posted March 9, 2013 Check the tow electrics socket for shorts first (if you have one) Quote Link to comment Share on other sites More sharing options...
101sean Posted March 9, 2013 Share Posted March 9, 2013 That does sound like a typical earthing issue. Quote Link to comment Share on other sites More sharing options...
alfy Posted March 10, 2013 Author Share Posted March 10, 2013 thanks - yes I have tow bar / electrics - will check the latest - the fuse's started to blow again ( indicators -dash gauges , fuse blows when I indicate left ) and the brake fuse blows when i apply brakes !!! fed up now - alfy Quote Link to comment Share on other sites More sharing options...
Aragorn Posted March 10, 2013 Share Posted March 10, 2013 its quite likely wires have chafed thru on the chassis loom, might be worthwhile pulling the whole loom out and inspecting it? Quote Link to comment Share on other sites More sharing options...
101sean Posted March 10, 2013 Share Posted March 10, 2013 The towing electrics are simply plugged in, reach up behind a plastic cover above the crossmember behind the LH rear wheel and unplug it to see if the problem goes away. If not, remove the cover panel at the LH rear inside the back door and you'll see the wiring loom and variuos plgs where it branches off. Carefully check the loom and the plugs for chaffing, there should be enough slack to pull it through the grommets for a good look. If you can't find anything it could be chaffing inside the chassis as Aragorn says, I've seen it before but on a much older vehicle. Only cure is to full it out, repair it and run it along the top of the chassis. Quote Link to comment Share on other sites More sharing options...
alfy Posted March 10, 2013 Author Share Posted March 10, 2013 Thanks chaps - will check alfy Quote Link to comment Share on other sites More sharing options...
