Ian Barrett Posted February 6, 2013 Share Posted February 6, 2013 Hello chaps, I bought one of the LED light group buy work lamps and am looking for ideas for mounting it. I want the work lamp for the back of my truck cab but want to be able to unclip it and point it outside of the Landy if I want to change a wheel or if i drop something for instance. The light has a typical U shaped bracket with a hole in the bottom of the U for bolting it to whatever. Has anyone ideas of a quick release system? Thanks IanB Quote Link to comment Share on other sites More sharing options...
landroversforever Posted February 6, 2013 Share Posted February 6, 2013 For an LED work light I have an aluminium scaffold clamp thing (from X-Eng). That way I can mount it anywhere on the roll cage. However, I'm increasingly finding I don't have enough light for reversing, so I'm going to permanently mount it to the rear of the car. Quote Link to comment Share on other sites More sharing options...
Bluemoon Posted February 6, 2013 Share Posted February 6, 2013 I have a similiar idea as above but use a large plastic spring clamp as listed here http://www.ebay.co.uk/itm/LARGE-PLASTIC-SPRING-CLAMP-CLIP-6-EASY-GRIP-MARKETSTALL-WORK-BUILDING-CLIP-/281055358398?pt=UK_Hand_Tools_Equipment&hash=item4170346dbe tha led lamp is bolted thru one side and can be moved quickly, I use mine for camping and working on the motor. Brian Quote Link to comment Share on other sites More sharing options...
Night Train Posted February 6, 2013 Share Posted February 6, 2013 How about welding or bolting on an antiluce onto the bottom of the U bracket and then have convenient brackets, with holes in, in the places you would fit the lamp? If you want a general purpose clamp then I would go for one of http://www.axminster.co.uk/axminster-axminster-power-hand-clamp-prod809357/?src=2007_wk9'>these rather then a spring clamp, as you can squeze it tighter then the spring will hold, if needed. Quote Link to comment Share on other sites More sharing options...
Tiger Posted February 8, 2013 Share Posted February 8, 2013 2x quick release seat bolts from a bike Cut them short, tap a thread, pop in a couple of Rivnuts. This is what I'going to do for the 40" light bar, no way I'm leaving that on all the time Quote Link to comment Share on other sites More sharing options...
