tow bar bracket
One of the things still o/s from my rebuild is the towbar.
I have the actual ball and bracket attached, but not the brackets that go back onto the chassis - the struts, if you like.
The reason I haven't put it on is the towbar is for a 200tdi, but the back end of my chassis is TD5 style, hence the incompatibility.
What size steel should I be using to make some brackets up? And can it be flat, or does it need to be right angled like my original?
