Diablo Posted February 7, 2013 Share Posted February 7, 2013 One of the things still o/s from my rebuild is the towbar. I have the actual ball and bracket attached, but not the brackets that go back onto the chassis - the struts, if you like. The reason I haven't put it on is the towbar is for a 200tdi, but the back end of my chassis is TD5 style, hence the incompatibility. What size steel should I be using to make some brackets up? And can it be flat, or does it need to be right angled like my original? Quote Link to comment Share on other sites More sharing options...
UdderlyOffroad Posted February 7, 2013 Share Posted February 7, 2013 Have a read of this thread, it's for a 110: http://forums.lr4x4.com/index.php?showtopic=75763 the bracing bars on mine are 40 x 40 x 3mm 90 degree angle steel. hth. Quote Link to comment Share on other sites More sharing options...
Diablo Posted February 7, 2013 Author Share Posted February 7, 2013 ta Quote Link to comment Share on other sites More sharing options...
