mikec Posted February 10, 2013 Share Posted February 10, 2013 Hi guys so I've got the ms wired up, I think! Powered it up and connected to laptop. Had a few problems with it not connecting to a port but think I sorted that, now I I'm getting this message. Any ideas please? Quote Link to comment Share on other sites More sharing options...
mikec Posted February 10, 2013 Author Share Posted February 10, 2013 Just a thought but have I downloaded the wrong version of megatune? As it mentions ms2? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted February 10, 2013 Share Posted February 10, 2013 YES YOU HAVE The right one is on the CD I gave you !! DO NOT USE THE ABOVE UNDER ANY CIRCUMSTANCESNige Quote Link to comment Share on other sites More sharing options...
mikec Posted February 10, 2013 Author Share Posted February 10, 2013 Nige nothing on the cd other than the build manual. Do you have a link to the download? Cheers mike Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted February 10, 2013 Share Posted February 10, 2013 https://www.diyautotune.com/downloads/tuning_software/diyautotune_software_win_history.htm scroll down to 101007 build Download that REMOVE existing software 1st, then run that - it will work Nige Quote Link to comment Share on other sites More sharing options...
mikec Posted February 10, 2013 Author Share Posted February 10, 2013 Cheers nige, downloaded, plugged in tried it, turned over a few times but no go, then I've had some electrical "issues" I.e. no ignition lights with the key but I did if I put the full beam on! Now nothing so I'm guessing something's not quite right somewhere. I'll get there, might be the loony bin but ill get there!! Quote Link to comment Share on other sites More sharing options...
muttleyd Posted February 10, 2013 Share Posted February 10, 2013 Mike, make sure your coil feeds are live on cranking and running positon. I fell into that one as I had spurred of the ignition switch. Good luck, it is great when it finally runs Quote Link to comment Share on other sites More sharing options...
mikec Posted February 10, 2013 Author Share Posted February 10, 2013 Mike, make sure your coil feeds are live on cranking and running positon. I fell into that one as I had spurred of the ignition switch. Good luck, it is great when it finally runs I did know that but to be honest had forgot, I took the take off from the old coil live for the time being, ill check it though Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 11, 2013 Share Posted February 11, 2013 First off, if you have electrical issues sort them out before trying to do anything else. You have to tell megaTune which version of ECU you have using the configurator option: Which the takes you to something like this: Quote Link to comment Share on other sites More sharing options...
