keven.b Posted February 13, 2013 Share Posted February 13, 2013 Hi, i would be grateful for any advice, i have a problem with the instrument panel on my 97 reg.P38. whenever I switch anything with load on e. Air Con or lights on the instrument panel goes mad flashing and I lose indicators. I have had several auto electricians look and haven't been able to cure this. I have replaced the instrument panel but this has not cured the problem if i switch the load off the panel settles down and works OK again. I suspect that it may be a poor earth some where but haven't a clue where to look. Quote Link to comment Share on other sites More sharing options...
Escape Posted February 14, 2013 Share Posted February 14, 2013 RAVE is your friend. The instruments are controlled via the BECM under the RH seat, you can start by looking for corroded connections there. Quote Link to comment Share on other sites More sharing options...
