darthdicky Posted September 18, 2006 Share Posted September 18, 2006 I've got 4 wires, which ones go to which side? One from the distributor One from the tacho One (brown/white?) to the carb One through the bulkhead I'm fairly sure they stay in the two groups as I've put them there, but which is positive and which is negative? Thanks! Quote Link to comment Share on other sites More sharing options...
Diff Posted September 18, 2006 Share Posted September 18, 2006 I've got 4 wires, which ones go to which side?One from the distributor One from the tacho One (brown/white?) to the carb One through the bulkhead I'm fairly sure they stay in the two groups as I've put them there, but which is positive and which is negative? Thanks! Distributor and tacho to the negative terminal, bulkhead and carb to the positive. Regards, Diff Quote Link to comment Share on other sites More sharing options...
darthdicky Posted September 18, 2006 Author Share Posted September 18, 2006 Cheers Diff, I thought it was that way around but so many things have been swapped the last few days I just wanted to be sure! Thanks, Richard Quote Link to comment Share on other sites More sharing options...
