Guest Posted February 18, 2013 Share Posted February 18, 2013 It seems a life time ago that the lights arrived and I'm sure most of you have them fitted by now, however a few of you have asked about mounting suggestions I will post up photos of how mine are mounted but feel free to post your ideas up here. Jason. Quote Link to comment Share on other sites More sharing options...
smokinv8 Posted February 18, 2013 Share Posted February 18, 2013 "Most of you have them fitted by now".... Ummmm........No! Quote Link to comment Share on other sites More sharing options...
=jon= Posted February 18, 2013 Share Posted February 18, 2013 (quick clamps are not the recommended fixing method ) I got a company called Roc-Ard (http://www.roc-ard.co.uk/) to make me up a custom light bar with mounting tabs to suit the bar - it came to about £50 all in. I have no connection with them but I thought it was good value for something not off the shelf... It's very nicely made too, well worth it (but if you go order one based on the dimensions I gave, I measured the mounting holes badly so they would need slotting a bit...) Quote Link to comment Share on other sites More sharing options...
SPendrey Posted February 18, 2013 Share Posted February 18, 2013 I could show you a photo of the small one I bought... it is on the side in the garage By the way =jon=, have you checked your palms recently? Your car seems to have the dreaded 'black spot', if your hands do too then I believe pirate-lore says your time is up? Quote Link to comment Share on other sites More sharing options...
Guest Posted February 18, 2013 Share Posted February 18, 2013 I could show you a photo of the small one I bought... it is on the side in the garage By the way =jon=, have you checked your palms recently? Your car seems to have the dreaded 'black spot', if your hands do too then I believe pirate-lore says your time is up? There his go faster holes it adds 10mph to the top end and helps offset the go slower defender design!! Quote Link to comment Share on other sites More sharing options...
=jon= Posted February 18, 2013 Share Posted February 18, 2013 Arr, they be my go-faster holes, they be! Courtesy of one of it's many previous owners, along with the yellow blotches, the green blotches etc etc Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted February 18, 2013 Share Posted February 18, 2013 I removed the pukka Land Rover work-lamp and bracket off the back of my Puma, blanked one hole and fitted one of the small LED's in it's place: Quote Link to comment Share on other sites More sharing options...
Guest Posted February 18, 2013 Share Posted February 18, 2013 looks good Steve, what is the light output like? Jason. Quote Link to comment Share on other sites More sharing options...
muddychris300tdi Posted February 18, 2013 Share Posted February 18, 2013 Hopefully fitting my two work lights in the next few days. I'm going to use two cb aireal gutter brackets to fit mine to the back of the Disco. I will be able to point them to the side if I need to. Quote Link to comment Share on other sites More sharing options...
potato head Posted February 18, 2013 Share Posted February 18, 2013 Two work lights mounted above the gutter, they are really bright. http://dl.dropbox.com/u/81558042/2013-02-18%2020.27.58.jpg http://dl.dropbox.com/u/81558042/2013-02-18%2020.28.20.jpg Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted February 19, 2013 Share Posted February 19, 2013 looks good Steve, what is the light output like?Jason. Pretty good for a diddy light, certainly enough for working around the rear of the vehicle and locking gates etc. Quote Link to comment Share on other sites More sharing options...
zim Posted February 20, 2013 Share Posted February 20, 2013 Just on the off chance, if someone is looking to sell their light bar could you please drop me a pm. Got a night challenge coming up and fancy trying one. Thanks Gordon Quote Link to comment Share on other sites More sharing options...
zim Posted February 27, 2013 Share Posted February 27, 2013 This is how we put mine on. It's only temporary as it'll be removed after this night challenge. I put one of the smaller 7" ones on the back and that is also pretty bright ! Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted February 27, 2013 Share Posted February 27, 2013 Anyone know the current raw on the type ones ?? Thexwires are tiny almost wondering if a relay is needed ?? N Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted February 27, 2013 Share Posted February 27, 2013 Anyone know the current raw on the type ones ?? Thexwires are tiny almost wondering if a relay is needed ?? N It should be 3 amps at 12v but I measured one of mine and it was nearer 2.5 amps EDIT: No need for a relay .... current is so small you could probably just stick the wires in your mouth instead of bothering with a switch Quote Link to comment Share on other sites More sharing options...
ejparrott Posted February 28, 2013 Share Posted February 28, 2013 This is Nige....... Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 28, 2013 Share Posted February 28, 2013 Posting on an iPhone again... Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted February 28, 2013 Share Posted February 28, 2013 I think its got an engrish keyboard Quote Link to comment Share on other sites More sharing options...
zim Posted March 1, 2013 Share Posted March 1, 2013 Nige, the max draw we had on the 42" bar was about 15v with the engine running it dropped to about 14.5ish. The 7" draws about 3amp. I didn't check my total current draw last night, but with all my lights on the alternator is maxing out at 86A...oops... That is with 1 x 42" LED bar, 1 x 7" LED bar, 4 x spots, 4 x 18W LED light engines + cooling fans. G Quote Link to comment Share on other sites More sharing options...
muddychris300tdi Posted March 2, 2013 Share Posted March 2, 2013 Hopefully fitting my two work lights in the next few days. I'm going to use two cb aireal gutter brackets to fit mine to the back of the Disco. I will be able to point them to the side if I need to. Ok, tried fitting my work lights on the cb brackets I got and just not going to work. Having with the gutter being lower either side of of the back door the lights are either in the way of the door or sticking to far out the side and vunrerable. So i am going bolt them through the roof. I would like to be able to turn them to the side if needed so what would be the best way of doing this and keeping them water tight? Quote Link to comment Share on other sites More sharing options...
ejparrott Posted March 3, 2013 Share Posted March 3, 2013 You want a fixed fitting through the roof or it'll leak. A very crude way would be to put a long setscrew through from inside with a repair washer, smear in gunk of your choice, then repair washer and nut and gunk on top and do up tight. On the remaining exposed shank of the bolt use the common 'U' bracket that most lights seem to come with, and a fit this over the bolt. Use a wing nut then to hold in place. When you want to move it then you're not disturbing the seal around the roof, and it shouldn't leak. Quote Link to comment Share on other sites More sharing options...
muddychris300tdi Posted March 23, 2013 Share Posted March 23, 2013 Well I thought I would take advantage of the nice weather today and fit my lights that I brought of Martifers the other night. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 23, 2013 Share Posted March 23, 2013 Itching to mount my 4 on the cage, but yet to get round to it and have a looming MOT to get ready for instead Quote Link to comment Share on other sites More sharing options...
muddychris300tdi Posted March 24, 2013 Share Posted March 24, 2013 Went for a drive last night to try them out. Quote Link to comment Share on other sites More sharing options...
