ajh Posted February 18, 2013 Share Posted February 18, 2013 Just discovered my Koni Heavy-Track leaking oil, since I fitted the dual front shock mounts when I built things I think it's time to fit all 4. What I'm wondering is which I should fit. Terrafirma is the easiest/cheapest for me to get so I'd like to go with those. I was looking at some combination of big-bore and pro-sport. Since the outboard shock limits wheel movement a bit I was thinking of fitting the Pro-sport outboard and a Big-Bore inside the spring. Anyone done something like this and have feedback? This is a 110 with HD springs and 2" lift. I just need to order ASAP since I'm off the road until they arrive (again, though I probably have a set of old shocks in the back I can use if needed if I thought to keep any). Quote Link to comment Share on other sites More sharing options...
landroversforever Posted February 18, 2013 Share Posted February 18, 2013 I love my OME Nitrochargers all round, but they can be a little harsh. Would probably be over damped with two each side on the front. Quote Link to comment Share on other sites More sharing options...
ajh Posted February 18, 2013 Author Share Posted February 18, 2013 With the front swaybar fitted a bit of extra damping is needed. My main thought is ... would two different shock rates per side be bad? Should I just get 4 of the Pro-Sport instead of the bigger one for the inside-the coil. If I had bypass dampers available it'd be much easier to decide since I really only want the extra damping for high-speed/rough road durability so some that would only add in the first 50% of the stroke would probably be ideal (the way you set-up piggyback dampers for racing). Right now I'm leaning towards 4 TF120s in the front; then if the rears need replacement go with a set of Expedition Big-Bore there, or do the same 4-damper set-up there, though for that I'd need to get the mounts. Quote Link to comment Share on other sites More sharing options...
