brent 3045 Posted February 22, 2013 Share Posted February 22, 2013 Started my 90 up, then just seemed to cut out, wouldn't start or bump at all. Just seems to turn over now, no chance of running. Any ideas? Quote Link to comment Share on other sites More sharing options...
western Posted February 22, 2013 Share Posted February 22, 2013 check the fuel shutoff soleniod wire is intact & attached, also test for 12v on the wire when the engine is turned over by starter, if OK, it's probably a dead soleniod, Quote Link to comment Share on other sites More sharing options...
brent 3045 Posted February 22, 2013 Author Share Posted February 22, 2013 Ok thanks, will let you know Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted February 22, 2013 Share Posted February 22, 2013 or a broken timing belt. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted February 22, 2013 Share Posted February 22, 2013 Take the oil filler cap off and see of the rockers are going up and down while cranking Quote Link to comment Share on other sites More sharing options...
brent 3045 Posted February 22, 2013 Author Share Posted February 22, 2013 Just noticed a wire loose on fuel pump pushed it on, fired up straight away, moved it down drive and cut out again. Now won't start again Quote Link to comment Share on other sites More sharing options...
western Posted February 22, 2013 Share Posted February 22, 2013 try the wire again, if it starts, thats the problem, the terminal probably needs squeezing to close it up to get a secure connection. Quote Link to comment Share on other sites More sharing options...
brent 3045 Posted February 22, 2013 Author Share Posted February 22, 2013 Ok thanks for advice, appreciate it Quote Link to comment Share on other sites More sharing options...
western Posted February 22, 2013 Share Posted February 22, 2013 or it could be a dying or sticky soleniod, you'll need a 8mm socket or open end spanner to remove the wire connection tag & a ground down 24mm spanner to undo the soleniod, it's not a easy job to remove it. Quote Link to comment Share on other sites More sharing options...
brent 3045 Posted February 22, 2013 Author Share Posted February 22, 2013 It wa just connection mate, was really loose, squashed it tighter on, its stuck now. Cheers Quote Link to comment Share on other sites More sharing options...
western Posted February 22, 2013 Share Posted February 22, 2013 a nice easy & no cost [money] fix, we all like those, glad you found the problem. Quote Link to comment Share on other sites More sharing options...
