Team Idris Posted November 2, 2014 Share Posted November 2, 2014 It says IP55, but with a run of electrical tape around the edge when the lid is on, it's a solid water-proof, even if the lid warps in a few years. Did you know there are clear fronted versions? Any alarm LED's or indicators are safe on the inside then. Quote Link to comment Share on other sites More sharing options...
bobtail84 Posted November 3, 2014 Share Posted November 3, 2014 It says IP55, but with a run of electrical tape around the edge when the lid is on, it's a solid water-proof, even if the lid warps in a few years. Did you know there are clear fronted versions? Any alarm LED's or indicators are safe on the inside then. I did look other "water proof" boxes but unless you are under water for weeks at a time IP55 would be fine also the size was just right. I didn't find one of the right size with a clear lid but I will keep looking. Quote Link to comment Share on other sites More sharing options...
Team Idris Posted November 3, 2014 Share Posted November 3, 2014 Sitting here I guess those gel crystal bags are your best friend? I've got a larger clear front enclosure on the van. I put latches on instead of screws, because I very rarely go in there, but when I do, it's always in a rush I like the ones that turn a quarter-turn to unlatch and have a couple about the place. My dash-box one is even weirder, and has big plastic screws. If you undo two and leave two part way in, they act as a hinge. Never seen another like it, but it is neat ! The only time I've put electronics into water is on my robot fish. I went mad with that and milled an ally box with a bolt every 30mm and a gave it a 4mm lid with rubber gasket. I got carried away, as the box lives inside the waterproof body Quote Link to comment Share on other sites More sharing options...
Team Idris Posted November 5, 2014 Share Posted November 5, 2014 I bought an IMO EN23C today, IP66, 125 x 125 x 75mm, Clear front and plastic screws that cant fall out. It even came with a din rail ! It's for the porch, but it does look very 4x4 Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted November 6, 2014 Share Posted November 6, 2014 link? Quote Link to comment Share on other sites More sharing options...
Team Idris Posted November 7, 2014 Share Posted November 7, 2014 http://www.imopc.com/products/1940024http://www.rbstarelectrical.co.uk/products/imoen23Mine came from CEF Quote Link to comment Share on other sites More sharing options...
