gavfurn Posted March 7, 2013 Share Posted March 7, 2013 Newbie only had it few days, pulling off at junction or pulling off through gear change, it leaves a big black cloud behind, goes little sluggish, the only thing I can think is, I did fill the fuel tank fully an rest counter I always do with new motors, So thinking poss all the s@#t from the tank, n poss all carbon build up in the engine?? What do you think?? Any ideas please so will start with service an go from there, Quote Link to comment Share on other sites More sharing options...
gavfurn Posted March 7, 2013 Author Share Posted March 7, 2013 Reset counter Quote Link to comment Share on other sites More sharing options...
SPendrey Posted March 7, 2013 Share Posted March 7, 2013 Black smoke is often attributed to overfuelling, possibly from 'tuning'. See this thread (http://forums.lr4x4.com/index.php?showtopic=81708) and this link within it (http://www.landroverweb.com/Pdf-files/Tuning_Land_Rover_Tdi_engines_Rev_2.pdf). Could it be that the previous owner had been tinkering? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 7, 2013 Share Posted March 7, 2013 Could also be: Blocked air filter blocked intercoooler blocked inlet manifold Simple things first Quote Link to comment Share on other sites More sharing options...
bear Posted March 7, 2013 Share Posted March 7, 2013 I'd go for the air filter first. Griff Quote Link to comment Share on other sites More sharing options...
ejparrott Posted March 7, 2013 Share Posted March 7, 2013 Give it a service, change the air and fuel filter, then see if its still doing it. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 7, 2013 Share Posted March 7, 2013 Also collapsed hoses as I understand it.* * = There goes the entirety of my TDi knowledge. Quote Link to comment Share on other sites More sharing options...
gavfurn Posted March 7, 2013 Author Share Posted March 7, 2013 Well done oil change and filters oil n fuel, forgot do the air one, got it just forgot put it in, do that tomorrow when I do the glow plugs, hope I've done the fuel one right with the pump an all, ( how can you tell if not) first time ever don't fuel one. Quote Link to comment Share on other sites More sharing options...
JeffR Posted March 7, 2013 Share Posted March 7, 2013 Wack a can of injector cleaner in whilst you are on, won't do any harm Quote Link to comment Share on other sites More sharing options...
gavfurn Posted March 7, 2013 Author Share Posted March 7, 2013 any injector cleaner recomended?? never really liked putting thing in like that, did it once to an old car an blew the ring, so ever since not liked doing it, Quote Link to comment Share on other sites More sharing options...
ejparrott Posted March 8, 2013 Share Posted March 8, 2013 I use Redex Diesel on my 200TDi quite reguarly Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 8, 2013 Share Posted March 8, 2013 Forte stuff is very good. Quote Link to comment Share on other sites More sharing options...
disco-shane Posted March 8, 2013 Share Posted March 8, 2013 I used diesel magic on my 200tdi. Worked a treat Quote Link to comment Share on other sites More sharing options...
JeffR Posted March 8, 2013 Share Posted March 8, 2013 I tend to use whatever is cheapest in the local service station.... Quote Link to comment Share on other sites More sharing options...
gavfurn Posted March 8, 2013 Author Share Posted March 8, 2013 Service done glow plugs done, she sounds a hell of a lot better! Still kicking out some smoke, will have take her for a good run over the weekend see Quote Link to comment Share on other sites More sharing options...
disco-shane Posted March 9, 2013 Share Posted March 9, 2013 I also run Bio-diesel...smells lovely and good for the environment Quote Link to comment Share on other sites More sharing options...
gavfurn Posted March 10, 2013 Author Share Posted March 10, 2013 Bin for a run, alot better. Lol bit of smoke not as bad so it looks like it ain't bin serviced for donkeys, just some when put foot down when going through gears Quote Link to comment Share on other sites More sharing options...
ejparrott Posted March 10, 2013 Share Posted March 10, 2013 I get the same, see my thread on 'gearbox rattle', We're thinking mine could be that the injectors need looking at. Quote Link to comment Share on other sites More sharing options...
Dean1989 Posted March 18, 2013 Share Posted March 18, 2013 Could be injectors not reflowing enough fuel back in overspill pipes giving overfulling smoke or could be like an above post says pump adjustment is there any signs of tampering on the pump or could be turbo seals ? Quote Link to comment Share on other sites More sharing options...
