istruggle2gate11 Posted September 19, 2006 Share Posted September 19, 2006 Hi all, In a quandry here, just fitting a ARB diff, all going well until it comes to the bearings. The rover type diff has Timken bearings (LMS01349 inner, LMS501310 outer) but these wont fit the ARB. It seems the ARB (model RD56, 24 spline land rover) requires the inner bore of the bearing to be Ø45mm, where the original rover diff is Ø41.2 (ish). So is there a later type of diff bearing with a larger bore but the same od? I need Ø73.3 x Ø45 x 20mm wide. Help much apreciated. Quote Link to comment Share on other sites More sharing options...
istruggle2gate11 Posted September 19, 2006 Author Share Posted September 19, 2006 Can any one expand on this: Differential - 10 Spline Diffs - (2) - RTC2726 24 Spline Diffs - (2) - RTC3095 Off rimmer Bros website Quote Link to comment Share on other sites More sharing options...
Tonk Posted September 20, 2006 Share Posted September 20, 2006 24 spline ARB will require the later metric bearings (dont know which number that is though). i'm assuming u're fitting the locker into an imperial diff housing? if so u'll need bearing adaptors to make the bearings fit the casing. Quote Link to comment Share on other sites More sharing options...
istruggle2gate11 Posted September 20, 2006 Author Share Posted September 20, 2006 24 spline ARB will require the later metric bearings (dont know which number that is though). i'm assuming u're fitting the locker into an imperial diff housing? if so u'll need bearing adaptors to make the bearings fit the casing. Hi Tonk, It turns out that 24 spline diffs do have the later metric type, where 10 spline can be early metric type or imperial. So if you have a metric diff housing, with 24 spline then you need RTC3095 bearings which in the normal world is a LM102949 where a 10 spline metric is LM501349. Quote Link to comment Share on other sites More sharing options...
headhunter Posted September 20, 2006 Share Posted September 20, 2006 Hi all,In a quandry here, just fitting a ARB diff, all going well until it comes to the bearings. The rover type diff has Timken bearings (LMS01349 inner, LMS501310 outer) but these wont fit the ARB. It seems the ARB (model RD56, 24 spline land rover) requires the inner bore of the bearing to be Ø45mm, where the original rover diff is Ø41.2 (ish). So is there a later type of diff bearing with a larger bore but the same od? I need Ø73.3 x Ø45 x 20mm wide. Help much apreciated. I have here in front of me as supplied by Devon 4x4 an RD56 24spline ARB diff, with the correct Timken bearings. The Timken code is LM102949 9X049 for both bearings. On the Timken box there is an additional label "GI 87041 QTY 1 BEARING CORRESPONDING TO RTC3095 This kit is for my front axle on a 1998 110 300tdi. Hope this is useful. John Quote Link to comment Share on other sites More sharing options...
istruggle2gate11 Posted September 20, 2006 Author Share Posted September 20, 2006 I have here in front of me as supplied by Devon 4x4 an RD56 24spline ARB diff, with the correct Timken bearings. The Timken code is LM102949 9X049 for both bearings.On the Timken box there is an additional label "GI 87041 QTY 1 BEARING CORRESPONDING TO RTC3095 This kit is for my front axle on a 1998 110 300tdi. Hope this is useful. John Cheers John, Thats confirmed it now. Thanks. Quote Link to comment Share on other sites More sharing options...
istruggle2gate11 Posted September 20, 2006 Author Share Posted September 20, 2006 Quite a nice little piece of info here Quote Link to comment Share on other sites More sharing options...
JST Posted September 20, 2006 Share Posted September 20, 2006 Rog so thats no to the Quiaffe then?? Quote Link to comment Share on other sites More sharing options...
istruggle2gate11 Posted September 20, 2006 Author Share Posted September 20, 2006 Rog so thats no to the Quiaffe then?? No mate, still needed Quote Link to comment Share on other sites More sharing options...
JST Posted September 21, 2006 Share Posted September 21, 2006 when you next around then? Quote Link to comment Share on other sites More sharing options...
