Hybrid_From_Hell Posted March 29, 2013 Share Posted March 29, 2013 New msq coming over this morning to your email Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted March 29, 2013 Share Posted March 29, 2013 Msq sent to teamdumzim account sitting there waiting fer yer mr Quote Link to comment Share on other sites More sharing options...
zim Posted March 29, 2013 Author Share Posted March 29, 2013 Interesting mounting for the pas !!! That's factory fit for a P38, not normally seen due to the engine bay / bonnet. Thanks for the msq On the 4 wire lambda you sent, am i correct in assuming to just join the 2 white wires ? G Quote Link to comment Share on other sites More sharing options...
zim Posted March 30, 2013 Author Share Posted March 30, 2013 I had the rad switch in a little boss (in right of pic) connected to a 2" long hose at the bottom of the inlet... Didn't warm up at the same rate as the rest of the water, so knocked a housing up on the lathe. It also has a 5/8 UNF hole for my temp gauge and a 1/8 NPT that we could use as a bleed if required. The p38 steering pump doesn't seem to work well enough for the hydraulic steering, but will fiddle a bit more with it before swapping to the ZF74. G Quote Link to comment Share on other sites More sharing options...
