petrolhead63 Posted March 12, 2013 Share Posted March 12, 2013 I think I have a second water in fuel sensor gone duff on me. Warning light on again, changed filter and no water in it at all but light remains on. If I unplug the connector on the sensor in the filter the light goes off indicating it is the sensor at fault. I notice two types for sale. one has two little metal prongs on it, the other has a plastic washer separating two brass parts held together with a cross head screw. This being as mine and the previous one. Does anybody know if one is better than other? Quote Link to comment Share on other sites More sharing options...
clive-240 Posted March 18, 2014 Share Posted March 18, 2014 I have the same problem as you by the sounds my light started to flash on and off every now and again I had a new filter in my garage so decided to fit it now my light is on all the time so think it must be the sensor at fault mine is the same as yours rubber type o ring seperating the two brass parts looking on Ebay they are around £20 plus postage each so will be buying on when I get paid the light is only a warning light, there is no water in my fuel have checked so snesor must be at fault will try unpluging it tomorrow to see if it stays off Quote Link to comment Share on other sites More sharing options...
Divster Posted March 19, 2014 Share Posted March 19, 2014 They are highly sensitive. Got fed up with cleaning and changing mine so just disconnected the sensor in the end Quote Link to comment Share on other sites More sharing options...
BogMonster Posted March 20, 2014 Share Posted March 20, 2014 <snip> Sorted Quote Link to comment Share on other sites More sharing options...
bear Posted March 20, 2014 Share Posted March 20, 2014 In fact mines an 04 model and it never had one fitted from new! Griff Quote Link to comment Share on other sites More sharing options...
