andyandlew Posted March 23, 2013 Share Posted March 23, 2013 Hi there. I have a 1986 110 and am planning on fitting anti roll bars to it. From the 'net I can gather a Discovery ( 200+ 300 tdi) rear anti roll bar will fit the rear end of my 110. ( cheaper and more avalable second hand). The advice I need is the front where I have a Salisbury axle fitted. On a previous 127 I owned/built I had an ex Snatch anti roll bar on the front, this was fitted ahead of the front axle and I intend going down the same route with this 110 I have. I need to know, is this the same part as a standard front anti roll bar with anything else, the only difference being its orientation? From looking at pics on fleabay, my main parts supplier, the front anti roll bars look the same on disco 1 and rr classic and 90/110. I just need to be sure. Any advice would be gratefully recieved.Thanks. Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted March 23, 2013 Share Posted March 23, 2013 Can't help on the front though if it is a normal defender one they have used for the Salisbury then the Disco item will also fit. I have 300 tdi Disco ARBs front and rear on my 110. They are a straight swap though you need to buy the 4 bolt shackles and new bushes for the rear chassis end. If you are running +2" shocks on the rear then be aware that you will need to add spacers to the chassis mount Quote Link to comment Share on other sites More sharing options...
