Divster Posted September 21, 2006 Share Posted September 21, 2006 Could someone please tell me if the wheel studs in the spare wheel carrier have a part no. and if so, what it is? If the studs aren't a seperate part, does anyone know the thread pattern??? Quote Link to comment Share on other sites More sharing options...
Matt Neale Posted September 21, 2006 Share Posted September 21, 2006 Could someone please tell me if the wheel studs in the spare wheel carrier have a part no. and if so, what it is?If the studs aren't a seperate part, does anyone know the thread pattern??? Sorry Divster - ALR5693 Carrier load / tail door spare wheel assy That's complete - the studs aren't separate. (I used nuts/bolts when mine broke off) Matt Quote Link to comment Share on other sites More sharing options...
western Posted September 21, 2006 Share Posted September 21, 2006 get 3 wheel studs as fitted in the hubs & weld them into the carrier. Quote Link to comment Share on other sites More sharing options...
Divster Posted September 22, 2006 Author Share Posted September 22, 2006 I can only find part no.s for Disco 1 wheel studs. Does anyone know if there is a seperate part for D2??? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 22, 2006 Share Posted September 22, 2006 D2 studs are certainly different because though the wheel spanners are both 27mm, the stud is thinner on a D2, I think they are something like 14mm not 16mm, but it isn't a normal metric thread its a funny fine metric of some sort so a normal M14 or M16 bolt is different. However I have a feeling that the hub is a complete unit on a D2 and you can't change studs...? Will have a look when I get to work later if nobody else has come up with the answer.... Quote Link to comment Share on other sites More sharing options...
Divster Posted September 25, 2006 Author Share Posted September 25, 2006 D2 studs are certainly different because though the wheel spanners are both 27mm, the stud is thinner on a D2, I think they are something like 14mm not 16mm, but it isn't a normal metric thread its a funny fine metric of some sort so a normal M14 or M16 bolt is different. However I have a feeling that the hub is a complete unit on a D2 and you can't change studs...? Will have a look when I get to work later if nobody else has come up with the answer.... Have you had chance to have a look??? Cheers Dave Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 25, 2006 Share Posted September 25, 2006 Sorry I forgot ... but I just looked and as I thought the studs are not a separate part you have to buy the whole hub.... Remind me to check my D2 wheel nuts on a more regular basis Quote Link to comment Share on other sites More sharing options...
Andy Posted September 25, 2006 Share Posted September 25, 2006 Bogmonster - check your D2 wheel nuts on a more regular basis Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 25, 2006 Share Posted September 25, 2006 Thank you Squire Quote Link to comment Share on other sites More sharing options...
Andy Posted September 26, 2006 Share Posted September 26, 2006 my pleasure old chap Quote Link to comment Share on other sites More sharing options...
Divster Posted September 26, 2006 Author Share Posted September 26, 2006 Sorry I forgot ... but I just looked and as I thought the studs are not a separate part you have to buy the whole hub.... Remind me to check my D2 wheel nuts on a more regular basis Balls.....off to try and match the tread then. If that fails it looks like a new wheel carrier Quote Link to comment Share on other sites More sharing options...
