Absolutely correct dan, I have been to challenge events and suffered smashed diffs and broken shafts.
Take for example Jim Marsden at KOH - axle failures meant he couldn't continue the race.
Having a vehicle that is bombproof and beyond pays. Even if I never win anything, im going to be at every event, enjoying myself!
If i had deeper pockets id love some other axles, but Im not far wrong with these.
Out of interest, does anyone know how heavy nissan patrol y60 axles are?
ANYWAY!
Slightly better pictures for those of you interested in Ackerman
I've had 'cracked' off the brake callipers with a hammer, and had the discs spinning. All feels nice and 'tight' inside, clearly these axles haven't seen a great deal of use!
Found this at Pirate (Nissan H233B rear axle)
Y60/Y61 axle weights 136 kilogram
empty axle = 32 kg
diff clock = 40 kg
2x axle shaft + wheel hub = 34kg
Brake disks = 20kg
brake calliper = 10kg
Can you tell if you use one ram off road? I know it's unbalanced on speed, but I drove a tele-handler for years and could never 'feel' the difference when driving. It's like Gwyns steering-assist then.
Worth mentioning I thought if you are on a budget :)
Paint still on the axels, clean oil.....Looks like you've dropped on lucky there. They are ripe for a good kicking :D
Dont be such a pessimist!
How many challenge prepared 90's come under 2300kg? not many.
Im building this on a shoe string budget. I don't intend to have to keep paying for replacement parts. So yes unbreakable is what i need.
The pair of axles, with tyres will probably weigh around 900kg gives me over a ton for cage chassis engine drivetrain and winches plus your odds and ends. I don't foresee a problem.
breg90 is correct, weight is everything,
our previous challenge truck was 2300, the current buggy is 1900 +/- depending on event & it is a noticable differance, bearing in mind a creepy crawler on a beadlock rim is 60kg each, winches are roughly 50kg each (Gp's + 8274s) i think you will really struggle to get all your other parts of the build "built" for a ton in weight,
offroad at low speed i dont think Id be able to tell if i only use a single single ended ram. But for a little bit faster, it think it would get strange.
When ive got a spare 4 grand to spend on axles (that won't be as strong) i might consider it, but at the moment, ill happily be a little heavy.
If you're interested, I probably have a double ended, double acting ram from my 4 wheel steer experiments which you could have for beer money!
IIRC, they were 40mm bore, 250mm stroke with Female M16 threads in the ends and 1/4 BSP fittings. I may also still have the orbital valve (the bit you connect to the steering wheel) too.
Just for a weight comparison - my Suzuki Jimny based truck (with Toyota 80 Axles and Fedima tyres, internal and external cages and 1 x 8274) weighs in at 1120kg It's actually very impressive what it will climb without the lockers! I decided it was easier to start with a light vehicle and keep it light than start with a heavy one and make it lighter! However, I think even a heavy 90 is a better all round vehicle.
Si
Dirty Ninety,
Not trying to have a dig at you - you can only p*ss with the co*k you've got. But you can chose how to use and dress it!
The sport is about fighting gravity:
  • Get across the bog
  • climb the slippery slope
  • and so on
The axles may be bomb proof, but at 900kg are waaaayyyyy to heavy. They probably have their own gravity field!
For comparision a rover axle is ~ 130Kg front and 110 Kg back(dick braked). Volvo portal - add 15 - 20 KG to each of those.
If your limited in funds you need to be far more canny with the decisions you make compared to the average joe.
Simon R's approach -cheap as suzuki. Bung under some rover axles. 24 spline will last under a 1200KG car. Drive past every one. Or buy some G waggon axles?
Alternative build a tube style single seat lightweight buggy that will last on LR axles.
My attraction to LR axles for you is that they are cheap. If you think out of the box and make a light weight car to run on them you will drive right past the challenge 90 brigade...
Adrian
I don't think they weigh anything like 900kg i'd say they are under 450kg
Something very important to remember is that although the extra weight will have a slight effect on its abilities, they will not break EVER!!
When a days offroading is done I measure it by how much fun I've had, now this fun IS proportional to how capable my car is, what isn't fun is loading up a 10am because your chocolate axles have failed again
Fit the axles Chris, put your foot to the floor, and most importantly point and laugh when someone else breaks! (especially if they've taken this tiddle about your axles)
B Reg 90 - you learn by experimenting. If I listened to all the nay-Sayers along the way, I wouldn't have built anything! Some of the things have been great and some not so, but I learned from all of them.
I had the exact same response to putting heavy 80 series axles on a Suzuki - but it was for the same reason. I know that they will not break no matter what I do! (they have Longfield shafts too). This truck weighs 230kg more than my last one - but I felt it was worth it for the reliability, which so far has proven correct.
If weight was the be-all, we'd all be running around on Quads!
Chris - best of luck with your build. At the end of the day, it's your build and only you can decide what compromises you need to make.
Si
Simon,
Experimentation - agree
80 Series axles on Suzuki - don't see that as the same deal in my view, but that's just my view. You put strong enough axles on a light car, not monsters.
Wieght - IMHO my orignal observation stands. However it was just that - a observation that can be considered, acted on, laughed at, ignored or anything in between.
Adrian
Yeah i was probably massively over exaggerating at 900kg, i shall have to get a weighing scales out!
I suggest weighing them first before everyone starts having a go - then please add them to the weight thread for reference. I think you dont have a bad choice when it comes to axles - they will spin 40's quite happily while allowing you to compete on events were portals are not allowed. There are options to make these axles lighter at a later date; The Currie Rockjock allows you to fit the internals to an aluminium housing, while increasing groundclearance.
Keep the updates coming!
Daan
Chris,
Don't you already have a suitable ram?
Or won't it work on this axle setup?
Loving the beef by the way, breaking axles always used to p##s me off, especially as I never used a trailer. Stick with them or persuade Dan to build u a g wagen set.
Dan might chime in here, but I always had a sneaking suspicion that dual wheel sprinter axles and diffs could be used with g locking arrangements. Never got around to proving it. Love to know if it was possible to make a really strong off road axle from dual wheel van axles. The yanks have been doing this for years, but because in the UK there is no corresponding strong front axle we seem to have ignored the possibilities.
Chris,
The ram you kindly gave me is a little small for the size of wheels I intend to run, however if somebody wishes to have hydraulic steering on say up to 35" tyres with little or no scrub radius please pm me.
I shall get the axles weighed pronto. However, I'm not in the slightest bit worried. Im going to have plenty of engine bay room if I ever felt the need to fit a LSx v8 kicking out 600hp (might need to take out a loan though!)
Hopefully by next week ill have some updates. Payday soon don't ya know!
  • 4 weeks later...
How are you getting on with the axle conversion,
In my opinion I would bin the 80 rear and get a D70 or a GM14 bolt, the 80 is way to heavy and locker choice is limited, get hubs that will take a LR disk and re bracket to take LR callipers, this will save a load of weight and you can fit LR stud pattern rims,
