jwhitton Posted April 2, 2013 Share Posted April 2, 2013 Hello All, My Defender 300TDi washer jet plastic top has come off. Not sure if it should come off or it has broken off! When I push it back on it does not secure itself and I cannot see how it should fit back on. Has it broken, or am I just being stupid on how it fits? If a new one is required, how is it fitted? Please help! Thanks in advance. Jon Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted April 2, 2013 Share Posted April 2, 2013 you need a new one, you get at it by taking the top of the dash out. Better still fit one in each of the spare gromets under your wiper arms, you get alot more water on the screen. Quote Link to comment Share on other sites More sharing options...
JeffR Posted April 2, 2013 Share Posted April 2, 2013 If you have very small hands you can replace the jet thro the hole where the ashtray fits on top of the dash. It's a bit of a bugger but much easier than taking the dash top off. Quote Link to comment Share on other sites More sharing options...
Maverik Posted April 2, 2013 Share Posted April 2, 2013 Bit of a PITA to change I'm afrad, as VB says you have to remove the dash to get to it form the inside. Mav Quote Link to comment Share on other sites More sharing options...
smokinv8 Posted April 2, 2013 Share Posted April 2, 2013 Or do as I did and jam an aquarium "t piece" into the hole where the jet has broke and fix 2 lengths of aquarium tubing to it (one per wiper arm). Then find a couple of Peugeot 405 spray bars and cable tie them to your existing arms. These then spray 4 jets of water directly in front of each wiper blade. Quote Link to comment Share on other sites More sharing options...
cackshifter Posted April 2, 2013 Share Posted April 2, 2013 Good idea, (but not sure my wiper motor would be capable of bending the aquarium tubing) Quote Link to comment Share on other sites More sharing options...
studmuffin Posted April 2, 2013 Share Posted April 2, 2013 Dont wish to hi-jack your thread, but on a similar issue- I have a TD5 -90 where I set up the washers to both be perfect on the middle of the front screen-- then after about a week one of them sprays underneath the wiper and the other one sprays over the top of the screen and hits the car following! or dribbles weakly and doesnt even reach the screen!! Funnily enuf the rear wiper never seems to mal-function, and the washer hits the rear screen plumb centre every time. Should I switch the rear washer for the front? LOL. Any remedies welcome. Quote Link to comment Share on other sites More sharing options...
Frax Posted April 2, 2013 Share Posted April 2, 2013 That happened to one of my ones 2 years ago, the nozzle froze and dropped off. I just superglued it back on and it lasted for a year till I did a complete rebuild of my Defender. Quote Link to comment Share on other sites More sharing options...
Maverik Posted April 3, 2013 Share Posted April 3, 2013 if you only use just water in your squishers then you get mold growing in the tank which every so often ditatches and blocks a hole. Best thing to do is clean the tank and pipework, then always put some kind of detergent in the water, I've never had a problem. Mav Quote Link to comment Share on other sites More sharing options...
studmuffin Posted April 3, 2013 Share Posted April 3, 2013 Thanks very much. I sometimes use pre-mixed screen wash but if I run out I have been guilty of filling up with just tap water. Will clean it out when it warms up a bit outside. Flippin freezin again today! Cheers Studmuffin Quote Link to comment Share on other sites More sharing options...
