C18RCH Posted April 8, 2013 Share Posted April 8, 2013 My washer pump was broken on my vehicle but finding a replacement was proving more hassle than it was worth since the pump was threaded and all the other appear to be push on so I decided a new bottle wa the answer, so having picked up a bargain at Newbury at the weekend, I am now faced with another problem. What is the part muber for the loom that connects to these types of pump (mine is the older blade type connection): http://www.ebay.co.uk/itm/Landrover-defender-windscreen-washer-bottle-double-pump-/290874183267?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item43b973ce63&nma=true&si=%252Fb0GbMEZWDmSAn4VtQ4ifA2n4KI%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557#ht_42wt_1172 Or, where can I buy these types of connctors to fix on to my loom? Cheers, Rich P. S sorry for the ebay link but it was easier than taking and posting a pic. Quote Link to comment Share on other sites More sharing options...
western Posted April 8, 2013 Share Posted April 8, 2013 Send PaulMc a PM, he can sort the plugs for you, they are the same as used on 300tdi side & indicator lights, if paul can't help, Vehicle wiring products or polevolt can supply these. Quote Link to comment Share on other sites More sharing options...
PaulMc Posted April 8, 2013 Share Posted April 8, 2013 The newer pumps use Econoseal connectors, which can be bought from Polevolt - http://www.polevolt.co.uk/acatalog/info_ESC2F.html Don't worry about the different coloured connectors/pumps, the keyways are the same between the Black and Red versions. Or, if you don't want to crimp the terminals to your existing harness, Land Rover do a 'service' link harness for fitting newer pumps into older vehicles - AMR3849 http://www.rimmerbros.co.uk/Item--i-AMR3849 Britcar do a Britpart and Allmakes version that's a bit cheaper than Genuine (the Britpart one is pictured with a Red Econoseal connector) - Britpart (even they couldn't f*** this up, could they ) http://www.brit-car.co.uk/product.php/188962/0/wiring_harness_washer_pump_def_rrc Allmakes http://www.brit-car.co.uk/product.php/202019/0/wiring_harness_washer_pump_def_rrc . Quote Link to comment Share on other sites More sharing options...
C18RCH Posted April 8, 2013 Author Share Posted April 8, 2013 Thanks for that gents. As it happens I've just found the same things myself: http://www.paddockspares.com/amr3849-link-lead.html Cheers, Rich Quote Link to comment Share on other sites More sharing options...
