The wheels with the yellow bands are what offends fridge....
Share this post
Link to post
This one was originally red with a black rim so not much better.
The wheel is a mach 5 beadlock wheel this one has a clamp ring sandwiched between the outer rim and main wheel. The other 4 have the clamp ring welded to the main part of the wheel and it's just the outer rim that bolts on.
Mike
Share this post
Link to post
After I posted I realised that might have been the case rather than mismatched wheels.
  • Like 1
Share this post
Link to post
17 hours ago, Stellaghost said:
Liking the rim supports where do you get them from Mike regards Stephen
Do you mean the pyramids? Google 'painters pyramid' :)
Share this post
Link to post
Ahh yes they belong to work. Easily made though.
Mike
Share this post
Link to post
That's exactly what I meant I was looking from a handy gadget point of view not taking anything away from your wheels they look great fancying yellow for stuff on my portal project regards Stephen
Share this post
Link to post
I think those pyramids are a prime candidate for 3D printing :ph34r:
Share this post
Link to post
Well that's the transfer box changed just need a test run now. The original ones input bearings have died. I'm planning to replace the bearings, gaskets and seals on the original one and keep it as a spare.
Mike
Share this post
Link to post
Sounds like a plan....
I have a TB and R380 for that very purpose here...
Share this post
Link to post
I have a spare engine, gear box (only fits the ibex though) and now a transfer box. Oh and steering box that will fit either the 110 or ibex.
Mike
Share this post
Link to post
The wheel boxes in the back have an angle on them which does give more space but it means nothing sits on them. I want to be able to mount the fridge there for trips. Que some bent aluminium, rivets, a bungee and some bobbin's to locate the feet.
Mike
  • Like 1
Share this post
Link to post
Nice !
Share this post
Link to post
Finally managed to get a new windscreen cut this week. So out with the toughened screen in with a laminated replacement today. That should be safer and it better not leak with the amount of goo round it.
Mike
  • Like 1
Share this post
Link to post
Well the transfer box replacement hasn't been entirely smooth, Smooth being the operative word. After I changed the box I noticed a vibration between 40 and 50 mph. At first I thought uj but on further investigation I spotted an oscillation on the hand brake drum. Tonight I stripped it out and put a clock on the rear out put flange, sure enough something isn't right. Turns out the output shaft is bent, Lord knows how :moglite:. Yes you can get the shaft out with the box in the car and no I probably shouldn't of done what I have. I didn't have time to strip the other box and I don't really want to in case this one fails. So out with some vee blocks and the clock, yep it's definitely bent. Of coarse I didn't mark the high spot and put it in my press :blink: I wouldn't do that would I :ph34r:. Anyway it's back together now and I'll test drive it on my way to work in the morning.
Mike
  • Like 4
Share this post
Link to post
Good show, never give in, and all that ;)
Share this post
Link to post
Well done.
Marking stuff is sooo 20th century 😂
Share this post
Link to post
Couldn't drive quick enough this morning so I still don't know. Though when I briefly made it to 45mph it did feel ok.
Mike
Share this post
Link to post
We'll made it up to 70mph at the weekend and towed a trailer as well. Seems to be solved :SVAgoaway:.
Mike
  • Like 3
Share this post
Link to post
