miketomcat Posted 10 hours ago Author Share Posted 10 hours ago Gearbox is working fine and the leak seams to be sorted. The r380 appears to have a longer throw on the sticks, which meant I had to chop out the tunnel aperture. I needed to reinstate the flange the gaiter sits on. Trying the fiberglass in a tiny hole with everything in the way is fun. I had to create the new flange at the back and the front needs to be angled forward. Not the prettiest job but it'll work. However I couldn't get it to stay in low range, as the stick was still hitting the flange. The linkage for hi-low is on a spline at stick end so I was able to rotate one spline and shorten the link. Really fiddly to do as you either have to do it at arms length blind from below or through a tiny gap from above. I chose above, I now have fully working sticks and a gaiter that doesn't pop off. Mike Quote Link to comment Share on other sites More sharing options...
landroversforever Posted 7 hours ago Share Posted 7 hours ago I can’t remember…. Is that R380 any different ratio wise to the lt77? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted 4 hours ago Share Posted 4 hours ago 3 hours ago, landroversforever said: I can’t remember…. Is that R380 any different ratio wise to the lt77? If it is there's naff all in it, there's slight differences between the diesel and V8 variants in terms of ratios. 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted 4 hours ago Share Posted 4 hours ago V8 5th is higher if I remember correctly, just can’t remember if the lt77 was different. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted 2 hours ago Author Share Posted 2 hours ago Ashcroft's state the r380 has a taller 5th gear than the lt77. It certainly feels slightly taller with the r380 than the lt77, especially when towing. My lt77 was a V8 spec but I didn't notice a difference to the diesel spec lt77. Mike Quote Link to comment Share on other sites More sharing options...
