Jocklandjohn Posted April 9, 2013 Share Posted April 9, 2013 Has anyone got any experience of these? They look like a normal LR replacement (Paddocks) and the price is reasonable. Seems a good alternative to original ones. Any thoughts? Quote Link to comment Share on other sites More sharing options...
JeffR Posted April 9, 2013 Share Posted April 9, 2013 In general, Bilsteins are usually bloody good shocks. If it wasn't for the fact that I've just replaced mine I think I'd be placing an order.... Quote Link to comment Share on other sites More sharing options...
dantastic Posted April 9, 2013 Share Posted April 9, 2013 I've been running the bilstens for a year and a half now. Great shock for the road, very good handling. Too stiff (and short) for offroad. Don't get their steering damper tough - it's a gas damper and I found it was impossible to live with. Quote Link to comment Share on other sites More sharing options...
dantastic Posted April 9, 2013 Share Posted April 9, 2013 Actually, I have the Gas bilsteins and not that exact model - sorry! Quote Link to comment Share on other sites More sharing options...
Aragorn Posted April 9, 2013 Share Posted April 9, 2013 I've been running the bilstens for a year and a half now. Great shock for the road, very good handling. Too stiff (and short) for offroad. Does that suggest they're shorter than the standard landrover dampers? Quote Link to comment Share on other sites More sharing options...
Jocklandjohn Posted April 9, 2013 Author Share Posted April 9, 2013 Thanks chaps. They look ok and with Bilstein's reputation I doubt they'll be bad and given their scale of production I expect will offer reasonably good value for money. So I've placed an order. I'll pop back and give a verdict once they're fitted and I've run around on them. Cant be any worse than the kangaroo hopping about I'm currently experiencing when I hit anything resembling a ripple in the tarmac! Quote Link to comment Share on other sites More sharing options...
Big.Mike Posted April 9, 2013 Share Posted April 9, 2013 Hi All, Just to tag on to the end of this post... Which bilstein shock is best for overlanding? Or should I go for the Terra Firma TF124? Cheers, Mike Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted April 9, 2013 Share Posted April 9, 2013 Hi All, Just to tag on to the end of this post... Which bilstein shock is best for overlanding? Or should I go for the Terra Firma TF124? Cheers, Mike For overlanding i'd go for either Land Rover oem shocks or the Koni Heavy Trak's, nothing else. Quote Link to comment Share on other sites More sharing options...
Big.Mike Posted April 9, 2013 Share Posted April 9, 2013 For overlanding i'd go for either Land Rover oem shocks or the Koni Heavy Trak's, nothing else. Go on then, I've got a 2" lift, what Koni do I need? Also, do I need axle stands and a trolley jack to change the shocks? Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted April 9, 2013 Share Posted April 9, 2013 just koni heavy traks +2. Paddocks were cheapest when i bought mine. You shouldnt need much more than spanners and some stilsens to change them. Quote Link to comment Share on other sites More sharing options...
dantastic Posted April 9, 2013 Share Posted April 9, 2013 A trolley jack and a high lift is the ideal combination. Then you can easily change shocks quickly. If the shocks have been on for a while you are likely to have to take the turret off as well. It is pretty common to snap at least one turret ring bolt. So it's a good idea to have a frest set of turret rings at hand. Quote Link to comment Share on other sites More sharing options...
Big.Mike Posted April 11, 2013 Share Posted April 11, 2013 A trolley jack and a high lift is the ideal combination. Then you can easily change shocks quickly.If the shocks have been on for a while you are likely to have to take the turret off as well. It is pretty common to snap at least one turret ring bolt. So it's a good idea to have a frest set of turret rings at hand. I'm only changing the back ones. Also, does anyone know how to adjust the latest koni Heavy tracks? (With the plastic not metal tops) Cheers, Mike Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted April 11, 2013 Share Posted April 11, 2013 Mine (with the plastic tops) are adjusted with a spanner shaped object with 2 pins sticking out. Quote Link to comment Share on other sites More sharing options...
Big.Mike Posted April 11, 2013 Share Posted April 11, 2013 Cheers for that, found the instructions in a fold of the box! My shocks must have been completely knackered, feels like a completely different motor! Going to do the fronts next pay day... Quote Link to comment Share on other sites More sharing options...
Jocklandjohn Posted April 11, 2013 Author Share Posted April 11, 2013 No go on the Bilstein B4 Blacks I'm afraid. Despite Paddocks showing 'in stock' they're not, and not getting any more. Back to the Armstrongs then I reckon. Quote Link to comment Share on other sites More sharing options...
