Filling Cooling System 300tdi...
Why did I only get 7 or 8 litres of coolant back into my defender ?
I thought i drained it well from the bottom hose. I used rad flush and now I'm worried theres some left in when i refilled with Prestone ?
Any suggestions ?
didn't even know there was one. Where is it exactly ?
I think i might just do it again and this time flush into the heater from the rear connection and then from the front with the opposing pipe connected. I'll let the water come out via the top of the rad. At least then i know the system is full of clean water. I will then drain by the botton hose on put in ~7 liters of concentrate whcih will them make it full. The prestone goes from 50:50 to 70:30 so all is good with ~7 litres.
Another £14 wasted......
