ambtmannetje Posted April 13, 2013 Share Posted April 13, 2013 My TD5 (2004) makes strange slipping like sounds when accelerating. Driving away from standstill adds the rattling sound with TC light burning. Could this be the ABS taking control due to damaged sensor or something? It started after a tight turn (maximum steering angle), but I can't link this to the problem. In time it is getting less noisy...but we all know what that could mean. Any ideas. I will deactivated ABS to see if this solves the issue. Quote Link to comment Share on other sites More sharing options...
cackshifter Posted April 14, 2013 Share Posted April 14, 2013 Is it possible you might have damaged a CV on the tight turn - or maybe a halfshaft? If the TC thinks it is slipping I think it has to be a CV outer turning faster than the ECU thinks it ought to, maybe partially seized/gripping. Either way I'd investigate, starting at the front. Quote Link to comment Share on other sites More sharing options...
Daan Posted April 14, 2013 Share Posted April 14, 2013 Is it possible you might have damaged a CV on the tight turn - or maybe a halfshaft? If the TC thinks it is slipping I think it has to be a CV outer turning faster than the ECU thinks it ought to, maybe partially seized/gripping. Either way I'd investigate, starting at the front. I doubt the cv is slipping as such, but if it does, locking centre diff would stop it happening. Daan Quote Link to comment Share on other sites More sharing options...
cackshifter Posted April 14, 2013 Share Posted April 14, 2013 TBH it seems unlikely to me too, but abnormal mechanical noises are generally bad news. Seems hard to imagine what fault would get the TC going. Quote Link to comment Share on other sites More sharing options...
101sean Posted April 14, 2013 Share Posted April 14, 2013 Get it plugged in and faults read, It's most likely a sensor issue. I've a dodgy rear right sensor that's tried to lock the wheel a couple of times. On the to do list before I re-tax and use it again. Quote Link to comment Share on other sites More sharing options...
ambtmannetje Posted May 9, 2013 Author Share Posted May 9, 2013 Update: The rattling has disapearred and shortly after this the slipping sound. The only thing I did was cleaning the sensor area's on the front wheels, but this can't be the solution. When cleaning I noticed the swivel cap was rusty and also received a tip to solve this (stc3435 lubricant). If it (rattling and/or slipping) comes back I will take apart the problem area. Thks for your responses. Rgds, Arnoud Quote Link to comment Share on other sites More sharing options...
