need4speed Posted April 17, 2013 Share Posted April 17, 2013 Can the seatbox be removed independantly of the sill uprights, or do the uprights need to be unsecured from the tub at the same time? My setup had nuts/bolts going through the whole lot (seatbox / sill uprights / tub) which i dont think is correct. Can someone please confirm? Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted April 17, 2013 Share Posted April 17, 2013 Hi, I believe you can't as there are two nuts/bolts holding the three parts together. When I removed my seatbox I just supported the sills at the tub end. You could fit the bolts back in loosly to support the sill in the mean time. Steve Quote Link to comment Share on other sites More sharing options...
need4speed Posted April 17, 2013 Author Share Posted April 17, 2013 Like you Steve, mine just had nuts/bolts going through the 3 different assemblies. However page 759 of parts book shows bolts (10) going through seatbox from the front, while page 763 shows bolts (44) going through sill uprights from the back. This seems to suggest that they are both independant of each other, or is it just an error in the parts book? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted April 17, 2013 Share Posted April 17, 2013 Two nuts go through from the front of mine through the flanges on the seatbox, the front flange of the tub, and the upright of the sill itself. Same on every other vehicle of the same construction that I've seen/owned. You should be able to remove the seatbox without removing the sills and/or their uprights. Quote Link to comment Share on other sites More sharing options...
Les Brock Posted April 17, 2013 Share Posted April 17, 2013 What he said.... Quote Link to comment Share on other sites More sharing options...
