Turbo Oil Return Pipe Nut Size
Hi Guys,
Can anyone tell me the size of the nut on the bottom of the 200tdi turbo. I'm removing the manifold to have it drilled and tapped for an EGR sender and I'm all ready to take it off, only for that blasted nut.......
Thanks a million
Mat
Sorry... EGT.... fat finger slip :)
It is the nut above no.19; VB... my one has a steel braided hose running down to another steel pipe, with I'm guessing another 22mm nut at the bottom into the sump.
I'll see if I can get a 22mm spanner from a friend... there's not a whole lot of space to swing it though between the heater matrix, washer bottle and inner wing!
Any one have any other suggestions to take it off...
Cheers
Mat
Thanks a million for a the help lads... 22mm it was :) and it was a complete pain in the arse to remove!! "cracked" it with the spanner and ended up using a pair of pliers to slowly undo it.... 45 minutes!!!!
I'm really not looking forward to putting it back on... does anyone have any hints or techniques? manifold on first, last... I removed the washer bottle to get the spanner in.
Cheers
Mat
Get a 22mm ring spanner and cut a slot on the ring so it slots over the pipe, still a slow job but more places for the spanner to grip the nut.
You won't get it tight tight as the ring will open up and slip round bit it will suffice until you get the final Nop with the open end.
Will.
Will.
Good call... I'll give that a go... how much should you pay for a 22mm spanner?
£5- 50 I'd look at something like a draper or buy two silver line ones if you can.
Looking at my silver line catalogue 449371 20x22mm is £4.57 bi hex ring spanner.
We sell draper and silver line at work if you can get away with something more cheesey silver line is more palatable to hack up.
