kinky kirky Posted April 18, 2013 Share Posted April 18, 2013 Hi all, My tailgate and window were working fine the other day, then the next day, nothing. I can't open it and I've tried with the key, not even a click. The back window won't work, even from the dashboard switch, again not even a click from the switch. The only thing that does work is the wiper/washer. I'm not sure if the light for the number plate is working but then I'm not sure if it ever did but I'll have a look when I get a chance. The fuse for the window is ok, is there a relay that could have gone? Hope you guys can help Oh, its a S reg with the L series diesel. Quote Link to comment Share on other sites More sharing options...
Dezzie Posted April 20, 2013 Share Posted April 20, 2013 Hi. Have you checked the corrugated tube of wire that links the main body to the tailgate ? Is this damaged or severed ? Also, when I took the tailgate interior door plastic trim off mine, there was a black click on wire connector behind the handle. This may have come adrift. Mind you, you'll have to open the door to get the interior trim off. Quote Link to comment Share on other sites More sharing options...
simonr Posted April 21, 2013 Share Posted April 21, 2013 There is also an earth connection to the body on either side of the tailgate - you have to remove some of the interior trim to reveal them. These are commonly a problem with the lock in particular. Si Quote Link to comment Share on other sites More sharing options...
