Salisbury servicing
Dan110
Hi there,
Just wondered if anyone can recommend a good place to get my Salisbury Diff looked at in Kent/West Kent? I've tried the search but nothing turned up.
No particular problem with it, it's just not as young as it once was and I wanted to give it the once over to make it more of a known quantity. I'm told Salisbury's are near-impossible to work on at home?
Cheers
Dan
Did you know Ford called the Salisbury the Bullit axle. Supposed to be bullit proof....
As for getting one serviced I have no idea. The only people that I know of that have been taught are the MOD fitters.
I keep saying, I've done three, two on a Ford course and one in a workshop. I promised myself I would never do another.
They are doable at home. All you need is the workshop manual for one.
Okay thanks for that. I thought you needed some kind of tool to stretch the casing open?
It's on a 1986 ex MOD 110, no problems noticed aside from a little 'slop' in the drivetrain generally.....What's the consensus - if it ain't broke.....?
No, i'm pretty much a plucky amateur so not approaching the job with much in the way of relevant knowledge!
I'll look into that first though if you think that's a likely culprit.
Thanks again for the comments......
Before condeming the diff on grounds of slack in the drive train, make sure its not the rest of the drive train - disconnect the rear prop and check the diff inout flange by hand. A 1986 110 should have an LT77 gearbox and LT230 transfer box, and I would say a solid input gear between LT77 and LT230. Lots of drive train slack will appear here, when the splines on the LT77 mainshaft wear out due to lack of lubrication.
You don't even really need a diff spreader.
While a spreader is nice a couple of tyre levers will get the centre out and careful persuasion gets it back in.
That's all most of us use on this side of the world when fitting lockers.
BTW, the Maxi Drive Sals 'spreader' was clever, rather than spreading the case across the journals it compressed the case vertically, springing the case horizontally.
Nice.
