dirtydiesel Posted February 4, 2015 Author Share Posted February 4, 2015 No progress from me, Matt my old apprentice has his running nice on the 603 pump in his BMW. I'm suffering from too many projects and too little time Quote Link to comment Share on other sites More sharing options...
landroversforever Posted February 4, 2015 Share Posted February 4, 2015 That's a shame . I seem to find myself exploring this option, but keeping the autobox, as my main engine idea seems to have fallen through. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted February 4, 2015 Share Posted February 4, 2015 Don't suppose you have the old autobox kicking around and are able to get an overall length and max diameter? Quote Link to comment Share on other sites More sharing options...
HoSS Posted February 5, 2015 Share Posted February 5, 2015 It would in all practical ways be a TD5 then I do like a 5-cylinder, but generally a petrol and connected to an Audi Not in any sense. The OM605 is a much better motor than the TD5 IMHO Quote Link to comment Share on other sites More sharing options...
Carloz Posted March 8, 2015 Share Posted March 8, 2015 I wonder how long the autobox will live with the torque of the 606 As long as you keep the OM606 standard it has a bit les power and torque than a standard 3.9/4.0 V8... A standard 4hp22 would live well behind a OM606 in standard shape so far I can see... Quote Link to comment Share on other sites More sharing options...
SeriousIIa Posted March 11, 2015 Share Posted March 11, 2015 Awesome thread and a lot of info. I am currently trying to squeeze in a M111 Mercedes petrol engine in my series 150Hp & 220Nm (not so impressive number with regards to a diesel but enough for my series with an LT77). The reason why I am replying is it uses the same bell housing patter as the OM603 and derivates. I already have an adapter plate to a LT77, so if anyone needs one I could try and let it copy in auto cad so you can have it fabbed up locally. Cheers, Bowy Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted March 11, 2015 Share Posted March 11, 2015 Is this for your 127 Bowy? Quote Link to comment Share on other sites More sharing options...
HoSS Posted March 17, 2015 Share Posted March 17, 2015 I can confirm that the Bosch ECU can be relatively easily de-immobilised and run standalone. Mine is now running Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted April 3, 2015 Share Posted April 3, 2015 Hoss, more information needs please!!! Quote Link to comment Share on other sites More sharing options...
HoSS Posted April 3, 2015 Share Posted April 3, 2015 I will make a write-up when i get a chance, stand by 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 4, 2015 Share Posted April 4, 2015 Now the proud owner of a vile purple Merc! Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted April 5, 2015 Share Posted April 5, 2015 is this turning into a incredibly slow race Ross? 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 5, 2015 Share Posted April 5, 2015 This is a race akin to two lorries on a dual carriageway! Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted April 5, 2015 Share Posted April 5, 2015 This is a race akin to two lorries on a dual carriageway! Going up a really steep hill with a full load ...... Quote Link to comment Share on other sites More sharing options...
Anderzander Posted April 5, 2015 Share Posted April 5, 2015 And limited to 55 ? Quote Link to comment Share on other sites More sharing options...
miketomcat Posted April 6, 2015 Share Posted April 6, 2015 And limited to 55 ?There never going to make it to 55 in a million years.Mike 2 Quote Link to comment Share on other sites More sharing options...
Defender Posted April 13, 2015 Share Posted April 13, 2015 Is anyone on the forum running an OM606 with a mechanical OM603 pump that hasn't been modified? What's the performance like? I was going to upgrade the pump to 6mm elements but the UK supplier now says he can only supply 7.5mm at a whopping £895 so I'm having second thoughts. This is way more power than I need for my application and I don't want to blow the gearbox apart or start buying modified clutches at £900. Also what has to be done to the turbo if you are running it as mechanical? Thanks, Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted April 13, 2015 Share Posted April 13, 2015 Is anyone on the forum running an OM606 with a mechanical OM603 pump that hasn't been modified? What's the performance like? I was going to upgrade the pump to 6mm elements but the UK supplier now says he can only supply 7.5mm at a whopping £895 so I'm having second thoughts. This is way more power than I need for my application and I don't want to blow the gearbox apart or start buying modified clutches at £900. Also what has to be done to the turbo if you are running it as mechanical? Thanks, I will be using 6mm elements out the EDC pump fitted to a mechanical om606 pump. Apparently with this setup with standard turbo youre good for 250bhp... i think. I'm going to be running the GazFab conversion plate to zf4hp22 autobox, so i dont really want any more than 250bhp for the time being. My conversion kit should arrive this week, engine can be fitted any time soon, mechanical pump and locking tool has arrived. Just need to have the elements swapped and can start to get it all bolted up. Quote Link to comment Share on other sites More sharing options...
daslandroverman Posted April 15, 2015 Share Posted April 15, 2015 How much does Mr Gazfab charge for the kit?, and will he do one for a manual, or is it auto only? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 15, 2015 Share Posted April 15, 2015 Not sure the manuals would take it to be honest! Maybe just as standard. But the standard max torque is 330nm. Quote Link to comment Share on other sites More sharing options...
iomlt Posted April 15, 2015 Share Posted April 15, 2015 I believe he is going to do a kit for a manual but not yet. Quote Link to comment Share on other sites More sharing options...
Mudmonkey Posted April 15, 2015 Share Posted April 15, 2015 Would also be interested in the price of gazfabs autobox conversion plate Quote Link to comment Share on other sites More sharing options...
Defender Posted April 15, 2015 Share Posted April 15, 2015 An OM606 with a 603 pump not modified will only give between 185nm to 310nm depending on the pump purchased. An R380 is so named because it will take 380nm of torque before it gives up, an LT95 will take 400nm+ so there are manuals that will work well behind even a tweaked OM606. Yep Gaz Fab is intending to do a manual conversion but hasn't done one yet, I ordered mine from SMT. DirtyNinety who's doing your element swap and how much? Any chance of borrowing your timing tool when your done please ? Does anyone know what needs to be done to the turbo or what actuator to buy? Does anyone know the timing tool part code as well? I think it should be 0 986 612 174 but I'm struggling to find one Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted April 16, 2015 Share Posted April 16, 2015 How much does Mr Gazfab charge for the kit?, and will he do one for a manual, or is it auto only? Would also be interested in the price of gazfabs autobox conversion plate £375 delivered! Mine came yesterday Quote Link to comment Share on other sites More sharing options...
muddychris300tdi Posted April 16, 2015 Share Posted April 16, 2015 So if you had room to have a remote transfer box, what manual gearbox would be best to use if you wanted a good amount of power. Quote Link to comment Share on other sites More sharing options...
