My deteriorated teflon coated balls.
Out of curiosity I've cleaned up my old chalices to see how deteriorated they were.
I'm shocked at how bad they are. There's quite a lot of rust in the unswept area, which i'd have expected to be pristine with there being lots of one shot in there.
I've no reason to believe that these aren't the originals, and the 110 is a 2003 so they're only just 10 years old.
Is this level of deterioration caused by bad/lack of maintenance or are teflon coated balls just poo?
My balls are 22yrs old (I wish I was !!!) and have always had EP90 - the casings have both drain and fill holes - are are pristine. No rust on the swept surfaces, but I don't know about the unswept surfaces. Possibly the One Shot was a step backward, and good old EP 80/90 is the way to go.
Mike
I'm with gear oil too. One shot is a bit runnier than alpha-gel, which used to let the inside of fabricated mower gearboxes go rusty. It seems fair that the thinner the lube, the better it will be at getting everywhere. One shot should have better film strength for CV's though.
I'll also blame the swivel housing breathers. As there arn't any, I suspect it will try to suck in water? And any that gets in cannot 'breath' out. Ever notice how they leak some days more than others? If I noted the flow on the S1 I bet I could log the high and low weather fronts :)
Maybe we're all just another pair of brake pipe breathers away from longer life swivel balls ;)
I did look at fitting drain plugs to the housings, but there was no obvious flat.
I may take another look at it.
Western mentioned he uses a squirt of oil. Would a 50/50 blend of one shot and oil give the best of both worlds or be worse than either?
If you are dunking your balls often that might not be a bad idea at all.
To drain the housing you can just remove one of the bottom pin bolts I think, I believe the holes are drilled right through during manufacturer.
With regard to fitting a breather, for owners of later (Td5-on) models you might be able to adapt an ABS top pin (which I believe is drilled through top to bottom) to fit a breather. Obviously this is only an option if you don't already have ABS!
It might be possible to modify the earlier pin types by drilling them in a similar fashion, even on pre-1994 models as there is a hole in the thrust washer and the bottom of the Railko bush. Failing that one of the top pin retaining bolts, the seal retaining bolts (if their holes are not blind - I can't remember) or even drilling and tapping the housing itself would be alternative options.
Yes they're drilled through.
Would the lower pin seal be ok with a bolt being removed and re-tightened?
I should think so. If you want to take extra precaution then take the wheel off and put the axle on a stand - that way there's very little weight/stress on the pins and any chance of movement is drastically reduced.
I usually drain and refill them with the wheels off anyway as it makes it easier to get to the drain/fill plugs.
I was just going to replace the filler plugs with pipe fittings? (BSPT)
I recon a good puddle is enough to get water in there when the seals get tired. Out in the rain and a blemish just lets a tiny bit in every steering wheel turn?
"Western mentioned he uses a squirt of oil. Would a 50/50 blend of one shot and oil give the best of both worlds or be worse than either?
Could easily be worse with a mix than one or the other, I hear you can reduce the film strength? I'm not too convinced though. And to be honest with the mechanical tech, if it holds ep90 it might as well have ep90. There are thicker gear oils though, like VG320, but I havn't looked into them. It is more like treacle.
Put a push fit in the middle of a filler plug?
How critical is the ep90 fill level?
Without a level hole it would be a bit hit and miss level wise.
I'd still like to know how the chalices got to be in the state that they are.
Didnt you have a spare axle? Cant you swap the swivel housings across, so you get the housings with the level/drain plug?
The axle is still under the Discovery 1 which is awaiting dismantling :(
But yes, i could take them off there...
Has to be moisture in there, and a lack of oil/grease on the rusty bits.
Both swivels had lots of one shot in them. Along with some oil from the axle casing.
I suppose they could have been run at some point with little or no lube and then refilled after that.
"Put a push fit in the middle of a filler plug?"
I was considering that first. But I think 1/2" BSPT (tapered) to 1/4" bsp male/male would be better. Then I could quarter hydraulic hose breather it. I am fairly sure it is half inch tapered thread. Best check?
I nearly drilled new small level plugs half way up my hubs, but I thought stay with the usual welding wire dip stick, to half fill them with gear oil.
A 10mm bolt works as a level though as long as there is a big fiiler to go with it. I tried that sucessfully on the rear KAM diff cover.
I bought new LR Genuine teflon balls, and thaykd only been on a couple of months and there's already signs of rust, I think It's just the thickness of the coating, I might try and paint the unswept area as I'm rebuilding my 90 atm and see if the paint sticks...
