CV joints - what to get?
cackshifter
Among my dependents I have Defenders, a 90 and a 110, both 300tdi so not spring chickens. The 110 is showing signs of needing a new n/s CV, and I have a feeling that the other side will probably also need it having travelled the same distance; the 90 having gone further will probably also need a couple ere too long. I have read with a bit of alarm the posts on CVs and realise the ultimate solution is Ashcroft and don't doubt it's a fit once and forget solution, but the bottom line is prohibitive. At the other end of the scale is Britpart, which is probably neither fit once nor forget, but costs less. I'm aware of the weakness of the later CVs and shafts. What I'm wondering is what would anyone recommend as being the 'good value' solution between those 2 extremes? I am looking I guess for something that doesn't cost as much as Ashcroft (which is probably overkill for me), but will be reliable for a while. And has anyone else tried Mr Van Snorkle's suggestion of taking the sharp radii off? I think genuine parts are heading towards Ashcroft territory in cost.
I notice LR direct do Hardy Spicer ones (supplied via Britpart) at 116.55 (+VAT) or genuine Britpart at 14.93. You can buy a lot of Britpart ones for the price of a Hardy Spicer. So the Britpart ones do look like a snip, as they say in A&E. I suppose, let's face it, you arent risking much money, and you can afford to change them more often
Going by cost alone isnt the best idea...
If they fail in a catastrophic manner and leave you stranded, the fact you can afford to fit 10 of them for the price of one genuine becomes less relevant?
The previous posters seem to suggest that they are at least equal to standard parts though.
Wholeheartedly agree that price alone shouldn't be the deciding factor.
The following graph from ashcrofts testing shows a pattern part tested as well, this is said by some to be a britpart CV. I can't however find a substantiated reference to that fact. Would be interesting if Dave were to comment on this thread. I don't see it hurting his sales as I'd argue he is selling to a different market.
His test rig
Even if they are Bearmach against Har Spicer the price is still pretty keen at 25.74. I agree going by cost alone isn't the best idea, but if you ignore cost you end up back at Ashcroft,it's the only 100% solution. If there's not much to choose in performance between the OEM and various pattern parts you might as well save your readies. Anything to be gained by cryogenic treating or taking off the sharp corners, or is general advice just wap it on?
