ejparrott Posted May 1, 2013 Share Posted May 1, 2013 I'm just gearing up for changing the gearbox in The 109 from Series 4-speed to Defender LT77. I know it makes no difference, but the engine is a Disco 200TDi, just so you know. I've obviously got the Series master, flexi and metal pipes, but does anyone know if the series clutch pipe will screw in to the LT77 slave cylinder? Or do I need to change out other bits too? Cheers Quote Link to comment Share on other sites More sharing options...
western Posted May 1, 2013 Share Posted May 1, 2013 591231 is the LT77 clutch slave cylinder part number, it's a Series 3 number too.http://www.lrseries.com/shop/product/listing/1662/591231-CLUTCH-SLAVE-CYLINDER.html so hopefully your pipe will screw in. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted May 1, 2013 Author Share Posted May 1, 2013 Wow..that was quick, Thanks Ralph! Quote Link to comment Share on other sites More sharing options...
western Posted May 1, 2013 Share Posted May 1, 2013 your welcome, don't blame me if it doesn't fit. I Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted May 1, 2013 Share Posted May 1, 2013 The LT77 in Heathers disco has M12 threads in the slave cylinder and thats a very early model. Quote Link to comment Share on other sites More sharing options...
Maverik Posted May 2, 2013 Share Posted May 2, 2013 If it doesn't fit you might need one of these... http://www.ebay.co.uk/itm/220990397728?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649#ht_1712wt_895 Quote Link to comment Share on other sites More sharing options...
Jon White Posted May 4, 2013 Share Posted May 4, 2013 The slave cylinder is the same, so you can just reuse your series one hence no plumbing to do. Jon Quote Link to comment Share on other sites More sharing options...
ejparrott Posted May 9, 2013 Author Share Posted May 9, 2013 That'll be the first thing to try then......what about pushrod, is it the same length or do I need to change that? (haven't got parts cat at work...) Quote Link to comment Share on other sites More sharing options...
western Posted May 9, 2013 Share Posted May 9, 2013 parts cat only gives numbers & no other info such as length of items like clutch pushrods. Quote Link to comment Share on other sites More sharing options...
