JeffR Posted May 4, 2013 Share Posted May 4, 2013 I own 2 defenders, a 3 door and a 5 door. Is anyone aware of a supplier that can get lock barrels for the doors and ignition that would use a common key for both vehicles (the missus and keys were not made for each other). So that would be 6 door lock barrels and 2 ignition barrels that use the same key. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted May 4, 2013 Share Posted May 4, 2013 Yes you should be able to do that. Have you asked a friendly storeman ot your local dealer. Failing that ask a good locksmith how mutch to do it. I know that all the Ford mk1 Works Escorts all had the same key number, the whole fleet. Quote Link to comment Share on other sites More sharing options...
JeffR Posted May 4, 2013 Author Share Posted May 4, 2013 Yes you should be able to do that. Have you asked a friendly storeman ot your local dealer. Failing that ask a good locksmith how mutch to do it. I know that all the Ford mk1 Works Escorts all had the same key number, the whole fleet. I can remember when I could open my old RS1600 with the keys to a mates Mexico. Quote Link to comment Share on other sites More sharing options...
Challo Posted May 4, 2013 Share Posted May 4, 2013 Hi Jeff, How about the sellers of eBay item number 251253879227 they may be able to approach their suppliers to sort you a set out. Failing that,it is possible, as stated above to get a locksmith to rekey them for you. Trouble will be finding a locksmith able. I was a locksmith about 20 years ago and I did rekey a Land rover ignition. Hope this helps Chris. Quote Link to comment Share on other sites More sharing options...
