Vague Steering after drop arm ball joint replacement
Hi,
I replaced the drop arm ball joint yesterday (what fun...) on my 1989 2.5 td 90, now the steering seems to have become less accurate. I can move the steering wheel 1/8 - 1/4 a turn without the wheels moving. On examination underneath, the ball joint/ steering arm is moving (ie the ball flexing in its seat), but not enough to get the rods mobile.
  • Have I screwed up the fitting? Not tightened enough?
  • Has it just uncovered a dodgy damper?
  • Is this what LR steering is supposed to feel like ? (Because it was more accurate with the knackered ball joint!!)
Thanks
No spring went back in - although I have since read two versions of which way it is supposed to go in (of course there are only 2 ways, but you know what I mean). All bits in, drag link reattached. Steering loose..... I don't think tightening the adjustment screw on the steering box will make any difference as the drop arm isn't wobbly. the play seems to be between the ball joint and the drag link.
Sorry I meant: No I didn't forget it, it went back in. That said I have just been out to check the drag link and discovered that I didn't refit the circlip properly and the guts have dropped out of the ball joint - kind of explaining why it is all feeling carp. Thats her off the road until I get another.........
