5th gear noise
'99 def 90 td5. I think my gear box is on the way out. It's started making a chirping noise in 5th which I believe is a layshaft bearing. I'm thinking a new recon box from ashcrofts but while its been done I'd like to swap the tbox to a 1.22 ratio as I do a few motorway miles and also get the clutch done.
The questions are:
1. Should i keep driving it until it goes bang?!
2. How long does it normally take before it goes bang?!
3. Would I need to change the ecu for the different tbox as the 99 ecu can't be re-mapped?
4. Which clutch kit to go for?
Thanks in advance.
I had similar a few years ago, sounded like a demented parrot trapped in the box and was told a layshaft bearing. Did around 1000 miles like it before I swapped the box.
Changing your Tbox makes no difference to the ECU, just need to swap the speedo drive over. I have a 1.22 box from a D1 in my Td5 which means the throttle map doesn't switch but I',m not too bothered. If you want to keep that and are fitting a SH Tbox from a D2 make sure it has the difflock.fitted.
