Range Rover Classic Hazard Lights Issue
Hi Guys,
Just doing my pre-MOT checks today - all of the left and right indicators work ok but when I use the hazard warning light switch only the indicators on the right hand side flash, none of the ones on the left flash.
Can't be a bulb issue as the lhs indicators flash when using the indicators normally.....
Any ideas appreciated.
thanks
Darren
I have that too. Wiggle the switch on the steering column and both work again. I sprayed some contact cleaner/enhancer into it and hold it slightly to one side (I forget which one) when I turn them on.
Proper fix would be a new switch, but it is integrated with other steering column switches and is quite an expensive part.
