EFI fuel pump flange diameter and PCD.
Morning all.
I was hoping someone could help me out.
I need to make a new fuel pickup to fit the mounting flange for an EFI fuel pump (Range Rover type - I suspect they're all the same).
I measured mine before I left home, but appear to have mislaid the piece of paper.
I seem to remember it's 5 bolt holes, but I can't remember the diameter of the flange or the PCD. Would someone be kind enough to measure theirs for me? I've attached a quick sketch of the measurements. If the PCD can't be measured easily, then the distance between the bolt holes would be fine - I can work it out from there.
