Floor Fixings
~I have had my floor and tunnel out and want to put it all back as it should be.
Over the years it has been out so many times that all the intended fixings have become muddled.
I have a mixture of self tapping screw into plastic red squares, nuts and bolts, and screw bolts into metal tags.
Does anyone know what it correct?
Do all the fixing holes go to red squares except the door edge which is nut and bolt?
If the red square containing holes have been drilled out what can I do?
Thanks
Ed
the red items are called loknuts & number is CZA4705L, normally supplied in packs of 10, these are a push fit in the holes.& go in the lower flange so floor panel sits over them,
the floor panels & tunnel use these, with nuts/bolts in the outer edge of floor panel big spire nuts at rear edge of floor panel to forward lower edge of the seatbox.
