jackmac Posted May 12, 2013 Share Posted May 12, 2013 Hi all, I've had both front hubs off for a few bits and bobs. One of them has gone back on fine, drive flange and all. The other one, I cannot get the CV shaft to stick far enough out of the stub axle to fit the circlip? It definitely had a circlip when I removed it, and I haven't removed the stub axle on this side. I've tried with the drive flange backwards to get some leverage on it, but even that doesn't fit. So it can't be that the hub isn't seated properly etc, because it's just not far enough out of the stub axle. Have tried putting a drive flange bolt into the CV shaft end end giving that a good pull - no luck. The wheels are pointing straight ahead. Any ideas, or do I just need to keep pulling on the CV shaft until it comes out a bit? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 12, 2013 Share Posted May 12, 2013 What's been changed? Quote Link to comment Share on other sites More sharing options...
jackmac Posted May 12, 2013 Author Share Posted May 12, 2013 On the side with the problem, just wheel bearings. Not touched swivel housing or stub axle, which is why I can't understand it... Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 12, 2013 Share Posted May 12, 2013 hmmm.... not sure then!! Quote Link to comment Share on other sites More sharing options...
CaptCarrot Posted May 12, 2013 Share Posted May 12, 2013 I've just had this and for me gently driving forward a few feet and turning the steering wheel moved the shaft out enough for me to get the shim and circlip back on....hopefully that doesn't cause any damage, I didn't do more than 6 foot back and forward a few times... Quote Link to comment Share on other sites More sharing options...
jackmac Posted May 12, 2013 Author Share Posted May 12, 2013 Excellent, that's why I love forums! I will get everything else back together first, then give that a go Quote Link to comment Share on other sites More sharing options...
Simon Smith Posted May 12, 2013 Share Posted May 12, 2013 Did you get the inner wheel bearing fully seated? If it's very tight you may not have got it fully home. I drive mine in with a hammer and one of the old races and you can hear the note change when it's seated. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 12, 2013 Share Posted May 12, 2013 Did you get the inner wheel bearing fully seated? If it's very tight you may not have got it fully home. I drive mine in with a hammer and one of the old races and you can hear the note change when it's seated. That sounds likely. Should be obvious when they are fully seated and if they were the only thing changed then a likely suspect. Quote Link to comment Share on other sites More sharing options...
jackmac Posted May 12, 2013 Author Share Posted May 12, 2013 Do you mean the race? Yes, definitely. As I said above, it can't be anything to do with that, since that would not affect how far it sticks out of the stub axle? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 12, 2013 Share Posted May 12, 2013 The drive flange position is relative to the hub, the relationship of that hub face to the stub axle is set by the bearings. Quote Link to comment Share on other sites More sharing options...
jackmac Posted May 12, 2013 Author Share Posted May 12, 2013 Yes, but as I said, I can't even fit the drive flange backwards. When it is on backwards, it just sits up against the stub axle, doesn't touch the hub at all. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 12, 2013 Share Posted May 12, 2013 Pictures paint a thousand words they say Quote Link to comment Share on other sites More sharing options...
reb78 Posted May 12, 2013 Share Posted May 12, 2013 If its the circlip, just put a bolt in the end of the shaft to pull it out far enough to get the circlip on. Quote Link to comment Share on other sites More sharing options...
jackmac Posted May 22, 2013 Author Share Posted May 22, 2013 Apologies for the long delay. Been sorting a few other bits. Driving the car back and forth, lock to lock, has not helped unfortunately. It's still not going on, I am just about to remove the swivel & hub as a whole and see if I can push the shaft through, refit circlip, then refit the hub etc! I have not got high hopes, it's a very metallic sound when I pull on the CV shaft and it goes as far as it can. It's definitely hitting something, which must be the swivel housing? Pictures below showing what I mean about it being relative to the stub axle. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 22, 2013 Share Posted May 22, 2013 I'm still thinking the bearings aren't seated properly. Would the flange go on if the hub was further inboard? Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted May 22, 2013 Share Posted May 22, 2013 There's only a tiny slither of thread showing on that stub axle, should be much more. As Ross says, bearings not seated properly, or maybe the hub seal is sticking out? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 22, 2013 Share Posted May 22, 2013 There's only a tiny slither of thread showing on that stub axle, should be much more. As Ross says, bearings not seated properly, or maybe the hub seal is sticking out? Haven't had mine off for a while, but I want to say I have about 4-5 threads showing. Mine are the early type though. Quote Link to comment Share on other sites More sharing options...
jackmac Posted May 23, 2013 Author Share Posted May 23, 2013 Took it to a local land rover specialist to confirm what you had all said. By the time I got there, he removed the drive flange cap, gave a tiny pull on the shaft and just slotted the circlip on I think a few miles of country lanes must have freed it up somehow. The reason there is so little thread left, by the way, is that they are TD5 stub axles with old style hub nuts etc. I am 99.9% certain they are correct Quote Link to comment Share on other sites More sharing options...
CaptCarrot Posted May 23, 2013 Share Posted May 23, 2013 Glad you're sorted Quote Link to comment Share on other sites More sharing options...
