dantastic Posted May 14, 2013 Share Posted May 14, 2013 Sorry if this has been answered before but here it goes. I have removed the EGR, cat and center box already. Looking for more upgrades. Intercooler seems to be the next thing on the list but is it worth it? what type of performance does it provide? I only have a standard turbo and I don't have a remap. This may be a silly question but, do you get what you pay for or will cheap and cheerful do? Quote Link to comment Share on other sites More sharing options...
Aragorn Posted May 14, 2013 Share Posted May 14, 2013 Without a remap you wont see much difference really. For the money spent, remap will see far larger gains than an intercooler will, so if you only plan to do one thing, do the remap. IF you want to get the maximum out of the truck, which means big remap and increased boost, then the intercooler upgrade will help, as the turbos working harder and producing more heat. You sort of get what you pay for, in that an expensive one will bolt in and connect up as per factory in about 10 minutes. A big ebay universal one will likely do just as good a job in terms of cooling, but its going to require fabrication, tweaking, pipework, adjustment etc etc. Quote Link to comment Share on other sites More sharing options...
dantastic Posted May 14, 2013 Author Share Posted May 14, 2013 I think that was about wht I was thinking alright. I will get a remap at some point just that you should probably get the intercooler before the remap so that can be taken into consideration when the truck is mapped. Otherwise you'd have to have it mapped twice. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted May 14, 2013 Share Posted May 14, 2013 yeh exactly, if you plan to have a basic "stage1" type map, then it wont really matter if you do it before or after the intercooler, as typically stage1 tunes are just generic software and designed to be used on a stock engine. If you plan to have stage 2>, then these are typically tuned to the modifications present on the car, and in these situations the additional cooling from the larger cooler will be a benefit. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 14, 2013 Share Posted May 14, 2013 Fitting just the intercooler will help in the short term before a proper remap. It will lower the intake temps which will help. Get the intercooler for now and you can have the remap at a later date Quote Link to comment Share on other sites More sharing options...
dantastic Posted May 14, 2013 Author Share Posted May 14, 2013 Will have to think about this a bit more I think.... They are pretty pricey.... Quote Link to comment Share on other sites More sharing options...
matfield Posted May 14, 2013 Share Posted May 14, 2013 Remap won't help when you bulldozing though.... Quote Link to comment Share on other sites More sharing options...
dantastic Posted May 14, 2013 Author Share Posted May 14, 2013 Not to worry Mat, I've Homer now, no more dozering Quote Link to comment Share on other sites More sharing options...
matfield Posted May 15, 2013 Share Posted May 15, 2013 I'd go for it... If I had the cash it would be the first thing I'd buy... and like you say, If you get it after you've had it remapped you're only going to have to have it done again! Quote Link to comment Share on other sites More sharing options...
dantastic Posted May 15, 2013 Author Share Posted May 15, 2013 Glad to hear you're a bad influence as always Mat Still undecided tho Quote Link to comment Share on other sites More sharing options...
DaveM-Sport Posted May 25, 2013 Share Posted May 25, 2013 Get it... Make the most of moving your reg plate off the grille Quote Link to comment Share on other sites More sharing options...
