Big.Mike Posted May 15, 2013 Share Posted May 15, 2013 My Dad bought a Jackall lift from an auction for £5 about 20 years ago. He used it to shift oak beams around on his barn conversion for a while. Then, in a fit of generosity not heard of before or since he gave it to me... Now, it doesn't work. Is there any way of servicing these beasts? Thanks, Mike Quote Link to comment Share on other sites More sharing options...
Jamie_grieve Posted May 15, 2013 Share Posted May 15, 2013 There's not much not to work really, you can take the pins out and take it apart and clean and lube it and it'll be fine. Take any corrosion off any sliding surfaces and maybe stick an inner valve spring in where the vertical spring goes to make it more reliable in the mud, Quote Link to comment Share on other sites More sharing options...
