Non legal exhaust?!
Came across this P reg 300tdi 90 in use on a farm today, thought it might be of interest.
Luckily the bonnet wasn't latched properly so I had to have a peek underneath to see how it worked! The under bonnet tubing and u bend appear to be from an old bath.
ee7276a2b8b75924831a0d68d2880fec_zps0cc7
f4b22b00520516c60e03775e03feca97_zpsa695
No sign of a tax disc so I guess its just used on the farm - Good,having a second useful life and being adapted with whats hanging around.The way it always was done and as long as its safe,none the worse for it.
None of the new Transit engined junk is ever going to last long enough to be useful in this way - unless you can find a TDI engine to retrofit.And to be frank I cant see any reason for it not to be road legal if it was to be taxed and put on the road.
in terms of "keeping it running with whats knocking around" i dont see why you'd have gone to the effort of hacking up that complete mess.
The same silencer box welded onto the normal downpipe and exiting under the floor would surely have worked just as well, and not looked ridiculous.
The heat from the exhaust is also running very close to that 90 degree boost hose, which WILL fail given time.
If he wanted to replicate a tractor stack for aesthetic reasons then i can sort of understand it, but if your doing something for aesthetics you wouldnt have made it look so awful!
Normally a 3-5mm hole is drilled at the lowest point to let water out. Most of the ones I know are registered as tractors etc, the cow **** doesn't get to them quite as quickly this way.
