FridgeFreezer Posted September 26, 2006 Share Posted September 26, 2006 I hope the Fraud 2.4 is better than whatever was in my last Trans(h)it, I've known gnats fart with more torque than that thing had Got a new Vivaro 1.9TDCi now, I think it has a VVT and I'm pretty sure I don't like it - it does go better than "normal" turbo but the engine is less predictable 'cos the turbo is never doing the same thing twice Quote Link to comment Share on other sites More sharing options...
reads90 Posted September 26, 2006 Share Posted September 26, 2006 I just have aproblem with tweaking and bosting a 200 TDi. After all it been 10 years since one left the Land Rover factory. So most of them will have 100,000 miles on them on near. i always thought doing it to a 60,000 truck would be ok but 100,000 plus then i think you are asking for trouble in the furture.Hence why i left my 200 TDi alone and changed other stuff BTW on the ford subject, Put it though a 4 wheel drive system and does not come up to much compaired to the 200 and 300 tdis. Also thought on the oposite what a 200 and 300 would be like in a transit. If the transit engine is not good in a Land Rover, or at least does not make it go as fast as a 300 TDi Quote Link to comment Share on other sites More sharing options...
GBMUD Posted September 27, 2006 Share Posted September 27, 2006 we have one of these- and oh my word is it quick. It comes with a six speed box does 45mpg up the motorway when loaded and goes like stink. we took it to france recently and it hit the rev limiter in 6th at 131mph indicated on the Tomtom!!!!! Bathtub Pete has one of those too. He has had his chipped! OMFG! Chris Quote Link to comment Share on other sites More sharing options...
red90 driver Posted September 27, 2006 Author Share Posted September 27, 2006 I just have aproblem with tweaking and bosting a 200 TDi. After all it been 10 years since one left the Land Rover factory. So most of them will have 100,000 miles on them on near. i always thought doing it to a 60,000 truck would be ok but 100,000 plus then i think you are asking for trouble in the furture.Hence why i left my 200 TDi alone and changed other stuff We only have 59000 miles on the engine from original. So, therefore we should be OK doing the turbo boost and fuelling without having to worry about old tired engines. Back to the possibility of going to a VVT, has anyone decided what would fit onto the 200TDi in place of the standard turbo? Just what IS the std turbo? a Garrett T4? What are the hybrid turbos that some seem to fit? Anyone? Bueller? Bueller? (Obscure reference) Quote Link to comment Share on other sites More sharing options...
Andy Posted September 27, 2006 Share Posted September 27, 2006 ive heard somewhere the stock Tdi turbo is a Garret T25 - same as a late escort cossie we took it to france recently and it hit the rev limiter in 6th at 131mph indicated on the Tomtom!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ekkk wow etc, sounds fun for a van. got a feeling those are FWD though? thats just wrong in my mind. trannys rule cause they go sideways Quote Link to comment Share on other sites More sharing options...
Aragorn Posted September 27, 2006 Share Posted September 27, 2006 it is a t25 as per escos however that refers to the core, wheel sizes, trim and ar ratios are very different between the two 2007 defender has a gft mt 82 transmission i found the ratios the other day on google on another lr site Quote Link to comment Share on other sites More sharing options...
white90 Posted September 28, 2006 Share Posted September 28, 2006 I just have aproblem with tweaking and bosting a 200 TDi. After all it been 10 years since one left the Land Rover factory. So most of them will have 100,000 miles on them on near. i always thought doing it to a 60,000 truck would be ok but 100,000 plus then i think you are asking for trouble in the furture.Hence why i left my 200 TDi alone and changed other stuffBTW on the ford subject, Put it though a 4 wheel drive system and does not come up to much compaired to the 200 and 300 tdis. Also thought on the oposite what a 200 and 300 would be like in a transit. If the transit engine is not good in a Land Rover, or at least does not make it go as fast as a 300 TDi mine was adjusted at 100k mark now showing 135 so far so good a TDi looked after will see 250k+ easily. 200-300 superb engines although the TD5 is growing on me Quote Link to comment Share on other sites More sharing options...
will_warne Posted September 28, 2006 Share Posted September 28, 2006 I think tuning a Tdi is fine at most mileages as long as you regularly change the oil and filters and watch EGT. As Tony says, they are very good engines! Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 28, 2006 Share Posted September 28, 2006 ive heard somewhere the stock Tdi turbo is a Garret T25 - same as a late escort cossie ekkk wow etc, sounds fun for a van. got a feeling those are FWD though? thats just wrong in my mind. trannys rule cause they go sideways Even the FWD ones if you try hard enough damn I hated that POS. Quote Link to comment Share on other sites More sharing options...
white90 Posted September 28, 2006 Share Posted September 28, 2006 ive heard somewhere the stock Tdi turbo is a Garret T25 - same as a late escort cossie ekkk wow etc, sounds fun for a van. got a feeling those are FWD though? thats just wrong in my mind. trannys rule cause they go sideways Escort Cosworth Turbo specs: Escort RS Cosworth Available :- 1992 to 1996 -------------------------------------------------------------------------------- The Escort Cosworth was based on the outgoing Sierra Cosworth floor pan, although this Escorts basic shape looks the same as the every day Mk5 Escort the rear 1/4's were built to be a little longer. This made the mating of the shell to the floor a little easier. Engine The Cosworth YBT engine was based on the Sierra Sapphire 4WD Cosworth unit. Bore 90.8 mm stroke 77mm Compression ratio 8:1 Weber-Marelli electronic fuel and engine management system Garrett T3/T04 turbocharger factory set at 0.8 bar boost pressure. Max power 227bhp at 6250 rpm with max torque 220 lb.ft at 3500 rpm Quote Link to comment Share on other sites More sharing options...
Aragorn Posted September 29, 2006 Share Posted September 29, 2006 early escorts had t34's, later ones had t25's the t25 only refers to the core not its compressor or turbine sizes rs turbo and saph cossie both have t3's rs turbo's turbo will struggle at 150hp saph's tyrbo will make 300hp then series name tells u very little aboyt actual turbo capabilities Quote Link to comment Share on other sites More sharing options...
jules Posted September 29, 2006 Share Posted September 29, 2006 we have one of these- and oh my word is it quick. It comes with a six speed box does 45mpg up the motorway when loaded and goes like stink. we took it to france recently and it hit the rev limiter in 6th at 131mph indicated on the Tomtom!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! in a fecking van. it also felt completely stable too! My dad had one of the big ones and when he bought it the 0-60 and top end is the same as a Jag E type. and it was good on fuel. 270,000 miles and it never missed a beat the body still looked like new as well. I did want to buy it off him to use as a survice truck but unfortunaly that was not possible Quote Link to comment Share on other sites More sharing options...
