john_grainger Posted May 25, 2013 Share Posted May 25, 2013 does anyone know if i can run 6 spot lights off 1 switch and still have 3 relays at the same timethanks Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 25, 2013 Share Posted May 25, 2013 So you want one switch to control the 6 lights, with them fed in pairs from 3 relays? Yes you can Quote Link to comment Share on other sites More sharing options...
matfield Posted May 25, 2013 Share Posted May 25, 2013 Put the relay trigger wire (probably from your full beam circuit) in parallel to pin 85 on each of the 3 relays. You will have 2 wires going into the connector for pin 85 for the first two relays, and the last will only have one, like a daisy chain. Quote Link to comment Share on other sites More sharing options...
