Aragorn Posted June 2, 2013 Share Posted June 2, 2013 Anyone know the torque settings for the Rear A-Frame? I've just installed it, looked in the RAVE manual and it seemed to suggest 130lb/ft for the bolts, however i've just tried tightening the two bolts that attach the A-Frame arms to the balljoint carrier to 130lbft and managed to strip the thread on one of the bolts, and i;ve probably ruined the other one too . So clearly 130lbft is rubbish. I suspect the big bolts on the chassis end will take 130lbft, but the smaller ones on the carrier will not. Does anyone know the correct figures for the three bolts on the A-Frame, ie Arms to chassis, arms to balljoint carrier, balljoint castle nut. Quote Link to comment Share on other sites More sharing options...
western Posted June 2, 2013 Share Posted June 2, 2013 A frame arms rear end to ball joint carrier to 115nm bracket to chassis 3 bolts per side to 47nm A frame forward end to chassis bracket manual just says tighten, no torque load. ball joint nut to 176nm & split pin. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted June 2, 2013 Author Share Posted June 2, 2013 Cheers, sounds a bit more sensible. Had to cut one of them off, other one undone, two new bolts on order. Quote Link to comment Share on other sites More sharing options...
Barry Furness Posted January 7, 2021 Share Posted January 7, 2021 If the 1/2" unf bolt has 3 dashes on the head it is a grade 5 the torque setting is 74 Lbft or 100Nm if the bolt has 6 dashes on the head it is a grade 8 torque setting 104 Lbft or 141 Nm 1 Quote Link to comment Share on other sites More sharing options...
