cadser Posted June 2, 2013 Share Posted June 2, 2013 My 05 freelander has started to smoke - Worse than Woodbines! TD4 2litre At constant revs whilst travelling the power will drop off and the car lurches as if i have pressed the brake - and smoke comes from the exhaust - black. Sometimes the power will came back and then off again and more smoke. If i let it idle whilst not travelling it seems ok! Just occatioanlly whilst idling there is a kind of deep roaring like air been dragged through some thing that is not open correctly and is making some thing resonate. Any help please before i take it to a garage will be appreciated. (or we buy any car). Brian Quote Link to comment Share on other sites More sharing options...
defv890 Posted June 4, 2013 Share Posted June 4, 2013 Hi sound like a spit hose from or to intercooler Check every hose for splits u can normally see the mess where it's sprayed oil out as well Just squeeze them and feel for split Quote Link to comment Share on other sites More sharing options...
reb78 Posted June 6, 2013 Share Posted June 6, 2013 As above^^^^ The intercooler hose to the front left of the engine bay as you look at it is often the culprit. Its a stupid design as it runs unprotected past one of the mounts for the engine cover and it rubs on the screw head there as the engine vibrates. Quote Link to comment Share on other sites More sharing options...
cadser Posted June 6, 2013 Author Share Posted June 6, 2013 Thanks for that. I will have a look at it over the weekend. Brian Quote Link to comment Share on other sites More sharing options...
evilruff Posted June 11, 2013 Share Posted June 11, 2013 Hi Have very similar problem, any advise will be really appreceated. Car: Freelander TD4 2001 Symptoms: - car starts and idle absolutely perfect - as soon as it drives below turbo limit everything looks just fine. - pushing gas pedal slowly from around 1.5-1.7 RPM makes car accelerate really really slow.. to explain, it's feels very similar to turbo lag.. - with gas pedal pushed harder car accelerates better, but with slight noise from compressor.. couple of days ago it starts to smoke a bit while accelerating... Question - am I on the right track thinking to dismount and inspect turbo compressor... with repair kit as a best case and replacement as a worst case scenario? Yuri P.S. sorry for weird technical English, I am not a native speaker =) Quote Link to comment Share on other sites More sharing options...
tim_roberts Posted June 12, 2013 Share Posted June 12, 2013 Check the hoses first, carefully. A small split will open considerably when the turbo kicks in and give exactly the symptoms you report. Quote Link to comment Share on other sites More sharing options...
evilruff Posted June 15, 2013 Share Posted June 15, 2013 Made an inspection today, actually everything seems to be much simpler.. an air pipe which goes to intake manifold dont have (or its gone) a lock (sorry no idea how it calls properly).. so it partially went out from plastic part of manifold making a hole.. I think it's a reason, so it sucks an extra air, more fuel with slight black smoke as a result... Quote Link to comment Share on other sites More sharing options...
cadser Posted June 17, 2013 Author Share Posted June 17, 2013 A small 2" diameter hose about 4" long was the problem. It was split. new one fitted and off we go, good as new. Thank you for your advice. Bri Quote Link to comment Share on other sites More sharing options...
